First post, by superfury
I'm using the FE /7 iw(immediate word) opcode in my emulator to execute handlers hardcoded in my emulator (function 0 being the BIOS POST, all other handlers are dynamically allocated). I know Dosbox uses it in the same way too to handle it's BIOS and MS-DOS interrupt handlers.
Are there other emulators using this opcode in this way as well or are only Dosbox and my x86EMU using the opcode this way? Does VirtualPC, VirtualBox, QEMU etc. use it too?
UniPCemu Git repository
