First post, by Imperious
Just thought I would let everyone see exactly what You get when You buy one of these cpus from here
http://www.ebay.com.au/itm/AMD-K6-III-400-ATZ … =item2c5638da3e
Obviously it has been literally desoldered from a laptop pcb. Solder blobs and slightly bent pins here and there meant It
doesn't go into the socket without doing some considerable work on it first. Fortunately it works fine at up to 600mhz on the
Epox board I have. I wouldn't recommend getting one if You have no soldering skills or patience.
