First post, by superfury
I've written myself an ATA-1 controller I'm using with my emulator:
https://bitbucket.org/superfury/x86emu/src/75 … ide.c?at=master
I can boot from a floppy and format, parition, add files, execute files and read files from it (I'm using the XT-IDE BIOS in 8-bit mode, set by the autodetect).
When I try to boot it(any mounted harddisk), I'm getting an error 80h (after which it tries to boot a floppy which also gives a 80h error resulting in a full reboot of the system). Anyone knows why this happens (It shouldn't timeout according to my logs?)
It's logging:
0:00:10:58.7.0304: Set features:0,0=01
0:00:10:58.8.0418: IDENTIFY:0,0=EC
0:00:12:90.5.0344: Set features:0,0=01
0:00:12:90.6.0139: Set features:0,0=82
0:00:12:90.6.0931: SEEK:0,0=70
0:00:12:90.6.0933: Seeked!
Edit: While debugging I notice that the hard drive isn't read when executing a hard disk read request (AH=2, DL=0x80). It's firing interupt 13h with AH=02h and DL=02h? It seems to try to load a 'third floppy drive' instead of the hard disk? Anyone knows why this happens?
UniPCemu Git repository
Reply 1 of 3, by superfury
When backtracing the disassembly given by my emulator I find this:
0:00:14:62.6.0699: C600:0AB7 (B480)MOVB AH, 80
0:00:14:62.6.0700: Registers:
0:00:14:62.6.0703: AX: A000, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.6.0705: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.6.0707: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
0:00:14:62.6.0709: IP: 0AB7, FLAGS: F246
0:00:14:62.6.0714: FLAGSINFO:c1P0a0ZstIdo1111
0:00:14:62.6.0746: Read from memory: 0009FC0D=80 (€)
0:00:14:62.6.0750: C600:0AB9 (A00D00)MOVB AL,[DS:000D]
0:00:14:62.6.0751: Registers:
0:00:14:62.6.0753: AX: 8000, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.6.0756: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.6.0758: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
0:00:14:62.6.0760: IP: 0AB9, FLAGS: F246
0:00:14:62.6.0764: FLAGSINFO:c1P0a0ZstIdo1111
0:00:14:62.6.0797: C600:0ABC (84E2)TESTB AH,DL
0:00:14:62.6.0799: Registers:
0:00:14:62.6.0801: AX: 8080, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.6.0804: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.6.0806: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
0:00:14:62.6.0808: IP: 0ABC, FLAGS: F246
0:00:14:62.6.0812: FLAGSINFO:c1P0a0ZstIdo1111
0:00:14:62.6.0866: C600:0ABE (7504)JNZ 0AC4
0:00:14:62.6.0868: Registers:
0:00:14:62.6.0870: AX: 8080, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.6.0872: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.6.0875: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
Show last 85 lines
0:00:14:62.6.0877: IP: 0ABE, FLAGS: F246
0:00:14:62.6.0881: FLAGSINFO:c1P0a0ZstIdo1111
0:00:14:62.6.0924: Read from memory: 0009FC0C=02 ()
0:00:14:62.6.0928: C600:0AC0 (A00C00)MOVB AL,[DS:000C]
0:00:14:62.6.0930: Registers:
0:00:14:62.6.0932: AX: 8080, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.6.0934: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.6.0937: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
0:00:14:62.6.0939: IP: 0AC0, FLAGS: F246
0:00:14:62.6.0943: FLAGSINFO:c1P0a0ZstIdo1111
0:00:14:62.6.0984: C600:0AC3 (98)CBW
0:00:14:62.6.0986: Registers:
0:00:14:62.6.0988: AX: 8002, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.6.0990: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.6.0993: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
0:00:14:62.6.0994: IP: 0AC3, FLAGS: F246
0:00:14:62.6.0999: FLAGSINFO:c1P0a0ZstIdo1111
0:00:14:62.7.0031: C600:0AC4 (38D4)CMPB AH,DL
0:00:14:62.7.0033: Registers:
0:00:14:62.7.0036: AX: 0002, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.7.0038: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.7.0040: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
0:00:14:62.7.0042: IP: 0AC4, FLAGS: F246
0:00:14:62.7.0046: FLAGSINFO:c1P0a0ZstIdo1111
0:00:14:62.7.0079: C600:0AC6 (7406)JZ 0ACE
0:00:14:62.7.0081: Registers:
0:00:14:62.7.0083: AX: 0002, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.7.0085: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.7.0088: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
0:00:14:62.7.0089: IP: 0AC6, FLAGS: F246
0:00:14:62.7.0094: FLAGSINFO:c1P0a0ZstIdo1111
0:00:14:62.7.0126: C600:0ACE (88C2)MOVB DL,AL
0:00:14:62.7.0128: Registers:
0:00:14:62.7.0131: AX: 0002, BX: 7C00, CX: 0001, DX: 0000
0:00:14:62.7.0133: CS: C600, DS: 9FC0, ES: 0000, SS: 0000
0:00:14:62.7.0135: SP: 7ED2, BP: 7ED4, SI: 00F8, DI: 0201
0:00:14:62.7.0137: IP: 0ACE, FLAGS: F246
0:00:14:62.7.0142: FLAGSINFO:c1P0a0ZstIdo1111
So the boot disk to be booted at 0009FC0C is incorrect (it contains 2 instead of 80h). Anyone can tell me why?
Edit: Found the problem: The BIOS detects 4 floppy drives (The BIOS Equipment word has bits 7&6 set to 1, so it detected 4 floppy drives (two times two floppy drives)). Now I just need to find out why the BIOS detects 4 floppy drives instead of 2 (actually installed floppy drives).
Reply 2 of 3, by superfury
I've fixed the problem: The PPI ports 0x62 and 0x63 needed to be added to properly detect the 2 floppy drives (instead of detecting 4 floppy drives and confusing the hard disk BIOS (drives A,B,C,D are floppy, drives E,F,G,H hard disk/cdrom in that case. It tries to boot the C drive (floppy #3) which doesn't exist, so it gives a timeout even through it's supposed to boot the harddisk.
Reply 3 of 3, by superfury
I've just found out another problem: For some reason the BIOS seems to detect 4 floppy drives instead of the 2 floppy drives installed. Anyone knows how the Turbo XT BIOS detects the amount of floppy drives installed (0,1,2,3 or 4 drives)?
