My kick around Thief box
First post, by squareguy
Well sometimes it's nice to have a box that has no sentimental value, no collectors value and something you aren't proud of that just has to be perfect. I keep trying to build my perfect box which means I easily end up with nothing to play on while it's being worked on, cleaned, waiting for parts, etc., etc.
Problem solved!
Take one of my Dell 4600's from a previous project. check.
It has already been cleaned. check.
Power supply already disassembled, cleaned, inspected and tested. check.
Remove RAM and install a single DDR 400, 256MB stick. check.
Leave whatever CPU is in it. check. (ended up being a Northwood 3.2)
Already has a 250GB Seagate IDE drive in it, DVD-ROM drive and floppy drive.
Slap one of my Quadro 380 XGL's in it. (Plenty of power for the task at hand)
Toss in a Turtle Beach Santa Cruz sound card for its front panel audio for the Dell case (I play Thief with headphones only), Sensaura 3D audio and good sound quality.
Load up Windows 98 SE, DirectX 7.0, drivers and Daemon tools.
Install Thief 1 and 2 (various others too) and rejoice with no jerking or lag. I know the AMD K6-3+ is really trying hard not to lag but she just doesn't have the horsepower for some of the 1998-2000 era games. She will still be treated with respect and finished for earlier stuff including DOS.
Never take this computer apart again and play the crap out of it, kick it around and play some more and resist the temptation to install a Quadro FX 3000. It just doesn't need it... or XP.
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 1 of 3, by CapnCrunch53
I know exactly what you mean. While working on my various builds like my Voodoo2 SLI and my Voodoo1 machines, I took the old family Gateway mini-tower, with its 1.1GHz Celeron, and tossed in my Voodoo3 2000 PCI and a spare Sound Blaster Live. It's easy to move around and work on with the small Gateway case (which I actually enjoy the looks of), much more straightforward and hassle-free than many of my other more specialized setups, and honestly as a result it gets more playtime. I also keep it in my room alongside my modern machines, which is sometimes a lot more convenient than going into the retro PC basement (which right now is an unusable mess anyways!).
PCs, Macs, old and new... too much stuff.
Reply 2 of 3, by PhilsComputerLab
Yea those games are a bit too demanding for the good old K6-III+.
Reply 3 of 3, by oerk
Yeah, the computers that just work and do the job get used the most. Constantly tinkering with their hardware is not beneficial for their intended purpose. It doesn't need to be perfect, it needs to work!
Compact cases for easy swapping in and out help too (I have one spot for a retro PC in my office, and I can only hook up one at a time). I own several big tower cases (with working computers inside), but I don't use them since they're a pain to move.
