First post, by sosone
In Sports Car GT doesnt work at all. Had to manually reset pc after playing. Can not do anything on pc after playing scgt
wrote:In Sports Car GT doesnt work at all. Had to manually reset pc after playing. Can not do anything on pc after playing scgt
You're using the Glide wrapper? Unfortunately there's an incompatibility between the Glide wrapper and AMD drivers. Dege can't fix it without access to a HD 7000 or 200/300 series card.
No. Because i had r9 290x few months ago and everything worked fine with dgvoodoo 2.4x.I am using same video driver now Catalyst 15.3 and 15.4
I currently own a 290x and I can't use the Glide wrapper at all. Games freeze immediately and the driver either resets or I have to close the game from taskmanager and then gpu load stays at 100% until I reboot.
I tried several different drivers and versions of dgVoodoo and none worked. The developer said it's because of a driver incompatibility.
DgVoodoo's DirectX wrapper works fine on the same videocard.
You should probably post your issue in the main thread.
dgVoodoo 2 for DirectX 11
