First post, by vytra
vytra
Offline
- Newbie
Hi,
I try BC31 small model with DOSBOX-v074, but farmalloc() can't allocate enough memory. I check it by farcoreleft() and got, what free only 1500 bytes. BC31 information show, that free is 1.5 MB. What can I do?
Thanks.
p.s.
.. may be in DOSBOX memory is calculated by KB, but must be by bytes?
p.s.2
.. I use Windows-7 Ultimate 32 bit, the same problem is if apps run without DOSBox 🙁 tomorrow needs to try other windows version.
S_O_L_V_E_D
- I found the problem solution, the length of the heap need to set in the BC31 debug option.
