I've got some BALLS (Sebastian Aaltonen, 1999)
First post, by Matth79
What was this game?
Dates back to Win9x, and was on of the first things I exercised my S3 Savage 4 on (needed a 3D card, I think it used OpenGL).
There was a ball, moving through a floating track (several tracks, and I think there were user made ones as well) - if it fell off, you lost!
I thought it was called "Balls of Steel", before the TV show and pinball game
[EDIT] It was called "I've got some BALLS" (Sebastian Aaltonen, 1999).
Reply 1 of 23, by leileilol
Labyrinth (D3D7)? Neverball (OpenGL)?
Reply 2 of 23, by Stiletto
I've got some BALLS (Sebastian Aaltonen, 1999)?
https://www.youtube.com/watch?v=tRLbAlcGtGs
do the Fandango!" - Queen
Stiletto
Reply 3 of 23, by Matth79
Stiletto wrote:
I've Got Some Balls (Sebastian Aaltonen, 1999)?
That was it! 😎
No luck running in Win7 - tried several compatibility options.
Reply 4 of 23, by Stiletto
Attached my install directory. Haven't tried to run it recently. I think it last ran for me in WinXP okay.
License:
I've got some BALLS v1.02 (3D-engine v4.0) (C) Sebastian Aaltonen 1999 --------------------------------------------- […]
This game is fully FREEWARE so you may copy it as much as
you want. The game is allowed to be distributed by all
distribution channels (like collection CDs, WWW-pages and BBS
etc.) without special authorization. Selfmade levels to the game
and other addons may be distributed freely as long as you
don't try to change the name of the author or try in any
other way to cause harm to author. If you make addons to
the game then remember also to mention that you have made them
yourself and they are not my productions. You are permitted
to make money with the game and it can be used for advertising
purposes, etc...
If anyone gets it to run, let me know what the tricks are 😀 Keys don't seem to be working at the menu...
Stiletto
Reply 5 of 23, by mr_bigmouth_502
I wonder if an XP VM would do the trick.
Reply 6 of 23, by Stiletto
Feels like overkill. There's probably some AppCompat flags that will make short work of it or something 😀
Stiletto
Reply 7 of 23, by Matth79
I got a static pic out of it with DGVoodo, but then after tweaking further, not even got that far now.
Reply 8 of 23, by leileilol
It's a D3D6 game. The DX SDK sample code device/res picker was recognizable
Works on PCem v10.1 with WinME guest and 3dfx Voodoo Graphics 😀
Reply 9 of 23, by Stiletto
If someone gets this running natively outside of a VM or emulator, please let us know and let us know how you did it 😀
Stiletto
Reply 10 of 23, by leileilol
So far I was able to go to the "menu" in 1920x1080x32, it crashes on start though because it does a nasty reinitialization
Reply 11 of 23, by balls
Hello, working just fine on windows 7 for me, i7 6700k, gpu r9 390. No 3rd party program needed. Enter key is set on left crtl, navigate with arrows and go back with esc. Im playing in 1920x1080x32 120fps. Some level are missing or maybe there is another verson, back in 2000 it was much more dificult to complete those levels 😊 and i dont remember any ollin.
Reply 12 of 23, by leileilol
That's because the GCN cards have much better legacy D3D compatibility (than HD5/6/7/8) since the Crimson drivers which weren't available at this time. 😀
Reply 13 of 23, by keenmaster486
Well, it's working on my system.
Specs:
Windows 7 Pro
i7 6500U
Intel HD graphics 520
Compatibility set to Windows 98/ME, works fine until you try to end to game and go back to the menu, then it crashes. I didn't do anything special other than that. As others have pointed out, the enter key is remapped to left ctrl.
World's foremost 486 enjoyer.
Reply 14 of 23, by Aideka
Runs on my pc without any compatibility settings: (Core i5 650, 8gb ram, Nvidia GTX 750Ti, Windows 7 64bit)
Reply 15 of 23, by Matth79
Revisited, Windows 10 and now a Geforce 750ti
Runs and get to title screen and music, but can't seem to access the menu
Reply 16 of 23, by keenmaster486
And I can't get it working in Wine or a Windows 7 VM (VirtualBox) either.
Reply 17 of 23, by liqmat
Made me think immediately of a game I used to play called Switchball.
Reply 18 of 23, by okenido
oh my GOD i spent this whole evening searching for this game, trying random "old 3D ball game win9x" keywords on google.. after HOURS of trying I finally found again this game I played a long time ago 😀
Reply 19 of 23, by cnz5
Stiletto wrote on 2015-11-25, 23:11:
I finally got it running in Wine with DxWrapper enabling Dd7to9, the default Specular setting is broken but "On (DX6.1+AMD FIXED)" seems to work
