tangocrk.com not working
First post, by rickford66
I just installed DOSBox version 0.74 on my Windows 7 64 bit machine. I'm attempting to get my Tango schematic and PCB software to work. I have the schematic software working better than I could have dreamed. My problem is with my PCB software. I have a batch file that calls tangocrk.com before launching pcb.exe, and it hangs up when it tries to run tangocrk.com. I've used this file before on older XP machines, but in DOSBox it hangs up. Has anyone seen this and if so, were you able to solve the problem? Thanks.
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Look at the batch file to see if it has any hardcoded path in it that doesn't match your mount path anymore. Could also be some kind of config file that has the old path set somewhere.
Best bet would be to try and get the exact same path as when it worked on XP - give us your current mount commands and the path it was in on XP.
Edit: and non-game programs are actually not supported by Dosbox 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 3, by keropi
I bet tangocrk.com is a tsr crack for the software...
