PC Chips M912 BIOS update for Am5x86 and Cyrix 5x86
First post, by feipoa
I have two PC Chips M912 motherboards which I got for free some years ago. One has PCB revision 1.4, the other is revision 1.7. I've seen 3 different jumper settings online which are supposedly for the AMD Am5x86, however none of them work. I power up the board, but there is no display shown on the monitor. This motherboard came with the following AMI BIOS revision,
BIOS Release = 12/02/1994
AMI Date = 7/25/94
Does anyone have a newer BIOS or know which jumper settings are proven to work with the Am5x86-133? The Intel DX4-100 works fine in Write-back mode. The Cyrix 5x86 as least attempts to boot, but stalls in early boot (perhaps related to the VLB SCSI card?).
This motherboard is based on the UMC Um4980 chipset. I realise it is not the most sought after board, but I at least would like to get it running with the Am5x86-160 so that I can compare it with an ASUS board based on the SiS471 chipset.
Reply 1 of 172, by BastlerMike
Fully configured for Am5x86:
The attachment PCChips M912_2.JPG is no longer available
Bios:
The attachment M912.rar is no longer available
Reply 2 of 172, by feipoa
Much appreciated! How did you find this BIOS version?
I also noticed that you are not using the P24D (Intel DX4 WB) jumper settings which are silk screened onto your motherboard.
Reply 4 of 172, by feipoa
I managed to find an m912 BIOS in my archives with date 12/02/1995X. I'm not sure what the X is for or where I found the BIOS, but I used it and it works fine with my AMD X5 at 160 MHz.
I tried using DIP-32 EEPROM's in the PC Chips M912, but they would not work, irregardless of what I set JP2 and JP3 at.
Reply 5 of 172, by jsp
Hi,
sorry for resurrecting this old thread, just wanted to report that I could get my m912 to work with an AMD 5x86 (at both 133 and 160 Mhz) thanks to the information of this post. I am using the bios contributed by feipoa, but probably the one uploaded by BlasterMike works just fine as well.
About reflashing the Bios, the rom in my board was an OTP so I had to desolder the IC from the motherboard and replace it with another eprom flashed with the appropriate bios. This proved to be quite tricky as the eprom was soldered directly to the board instead of being placed in a socket. I also had to buy a programmer (TL866) for flashing the bios into the new eprom. Finally I soldered a socket into the placed left after removing the old eprom to avoid having to repeat the process if I ever need to.
If anybody dares to go this route, my advice is to cut the pins of the soldered rom and extract each pin individually unless you have the proper tools for desoldering such a massive IC. I ended up damaging my board pretty significantly during the procedure, and unfortunately had to bridge 4 connections using wires from the eprom to the pins of the first ISA slot.The good news is that it's working, but I'm pretty sure I'll need to plate back some of the holes in the future as the connections don't look 100% reliable.
Next stage of this trip: replace the damn fake cache ICs. Lot's of desoldering+soldering (9x28 pins), it will have wait until next year 😁
Reply 6 of 172, by feipoa
Damaging some traces is just part of the learning curve. I'm sure its happened to everyone.
Reply 7 of 172, by mt777
What is the latest Award bios for this mobo?
I prefer Award then AMI and would like to update to the latest possible version (mine is from 11/01/94)
Reply 8 of 172, by Nexxen
jsp wrote on 2018-09-01, 18:10:
Hi, […]
Hi,
Have you tried replacing the fake chips? I would like to try that and see if it works, but a word of advice is welcome if someone has done it before. 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 9 of 172, by jsp
Hi,
sorry for the late response to this question, it's been a while since I logged in the forum. Unfortunately, I haven't had time to replace the fake cache chips on the board. It is pretty substantial amount of work, and I just don't have the time at the present time. If anybody has success with this please let us know!
Thanks
Nexxen wrote on 2020-03-19, 18:24:
Hi, […]
Hi,
Reply 10 of 172, by Nexxen
I am on the way and I "just" need to figure out the smd capacitors value that goes with the cache chips, as they aren't on the board.
Desoldering and resoldering is the real issue here... 🤣
I'll report back my results. I still have to benchmark the board before the changes to see how much it affected performance, but I guess that the 486 figures aren't going to change much as in the super benchmark in Marvin forum.
After 20+ years I want answers 😀
Reply 11 of 172, by ricardo.contieri
Hi all!
As this topic is "kinda" alive, I'd ask if anyone was able to get this version of the bios that was published back in the day on PCChips website.
M912 Mainboard:
9121201.bin checksum: * 2DC3 *
BIOS Date:12/01/1995
Board Description:UMC8498, UMC8496 Chips
BIOS Features:To support Cyrix5x86, AMD DX4
Source: http://web.archive.org/web/19980214052149fw_/ … _mainboard_bios
If anyone has captured that version, it would be great to share!
Thanks in advance!
Reply 12 of 172, by darry
ricardo.contieri wrote on 2020-09-16, 03:16:
Hi all! […]
Hi all!
M912 Mainboard:
Thanks in advance!
I found the filenames on the Internet . Not what you are looking for, but maybe of interest .
Hard to say what is actually newer .
9190914s.rom is in 980914s.zip
The attachment 980914s.zip is no longer available
9191016s.bin is in 961016s.zip
The attachment 961016s.zip is no longer available
https://web.archive.org/web/20010112030700/ht … port/mb_912.htm
EDIT: I can't even be sure these are actually for the M912 or not .
EDIT2: Found it here : https://www.elhvb.com/mboards/pcchips/486_M9x … M912/index.html But the file is unfortunately corrupted .[/s]
EDIT 3: Found it here and it seems OK .
https://www.elhvb.com/mobokive/archive/pcchip … 9951201_AMI.zip
The attachment 912_Bios_19951201_AMI.zip is no longer available
Reply 13 of 172, by darry
darry wrote on 2020-09-16, 03:52:
I found the filenames on the Internet . Not what you are looking for, but maybe of interest . Hard to say what is actually newe […]
Hi all! […]
Hi all!
M912 Mainboard:
Thanks in advance!
9190914s.rom is in 980914s.zip 980914s.zip
9191016s.bin is in 961016s.zip 961016s.zip
Replied to myself in order to bump because the file requested was found .
Reply 14 of 172, by jakethompson1
Hi all! […]
Hi all!
M912 Mainboard:
Thanks in advance!
I don't know how to check the checksum, but my board came with a 12/01/95 BIOS.
I wonder if you could compare cachechk numbers especially how cachechk -w compares to cachechk:
https://www.vogons.org/viewtopic.php?f=46&t=76564
Reply 15 of 172, by jakethompson1
jakethompson1 wrote on 2020-09-18, 00:08:
Hi all! […]
Hi all!
M912 Mainboard:
Thanks in advance!
I wonder if you could compare cachechk numbers especially how cachechk -w compares to cachechk: M912 v1.7 - both caches always perform as write through
Reply 16 of 172, by ricardo.contieri
Thanks to all who has sent those files! I guess they are not on the file section of Vogons... Now I just need one EPROM that can fit those bios and try them out!
Best,
Ricardo
Reply 17 of 172, by ricardo.contieri
Those two files didn't look like they belong to the M912. I guess M915 or something else? They are twice the size of the M912 rom.
EDIT2: Found it here : https://www.elhvb.com/mboards/pcchips/486_M9x … M912/index.html But the file is unfortunately corrupted . […]
Yeah! I managed to make this one work and I have an updated BIOS for Dec 1st 1995. It is quite funny that the info on the rom is very little on that release date, and even when I boot up, it does states that date, but also the older 1994 date.
Reply 18 of 172, by ricardo.contieri
Now I can't make this board recognize the writeback cache for my &EW Intel DX4-100 processor. I'm not sure if I should change jumpers on it from the standard DX-4 setting. I changed on the BIOS, but CPUCHK returns with L1 writethrough response.
I guess that the update for the BIOS also addressed the &EW spec for the Intel.
Any tips where to poke?
TIA
Reply 19 of 172, by jakethompson1
ricardo.contieri wrote on 2020-10-09, 02:01:
Now I can't make this board recognize the writeback cache for my &EW Intel DX4-100 processor. I'm not sure if I should change ju […]
TIA
From all that I've found working with this board and the similar ECS UM4981, the BIOS settings for L1 write-back/write-through merely inform the chipset of what type of CPU is installed. The reason I've run into this is the ECS 4981 BIOS doesn't configure the chipset properly, at least when I have an Am5x86 installed, and this causes the behavior of the A20 gate to be broken for me. You have to adjust the jumpers to switch the CPU to WB. The CPU determines whether it's WB or WT at the very moment of reset by checking the WB/WT# pin--long before any BIOS code has run or any CMOS settings are known. I believe this is to make them compatible as upgrade CPUs with old boards that don't have anything connected to that pin.
There should be three extra jumpers to set for a WB CPU. I believe these connect the WB/WT#, HITM#, and CACHE# pins. You can read a bit about what changes were made to the 486 pinout to accommodate WB it here. http://datasheets.chipdb.org/SGS%20Thomson/x86/486/4193.PDF
