First post, by kanecvr
Hi guys. So I got a FIC 486-VIP-IO2 and did manage to get it running, but memory read is HORRIBLE - about 21-22MB/sec making it the SLOWEST 486 board I've ever used. Here's the thing - this board has a lot of jumpers (IRQ Pull-downs, base address allocations and alike) and correctly setting it up fixes the slow memory read.
Problem is there are no proper jumper settings online - just some useless scans of a few pages of the board's manual that allow you to set it up for some of the most common CPUs at the time.
Does anyone have a complete manual for this board listing ALL jumpers and their functions?
This is a PDB binder of all settings I could find so far, as you can see it's pretty useless...
vip-io2.pdf
3.08 MiB
160 downloads
Reply 1 of 11, by brostenen
I think I saw almost all of the old fic manuals on their site. 😉
Reply 2 of 11, by kanecvr
They are incomplete. What I attached to the first post is from their website + other sources. I'm hoping someone has a complete manual for this thing.
I'm screwed aren't I?
Oh well, if I can't find a complete manual I'll just shove this in the "kind of unusable stuff" box.
Reply 3 of 11, by brostenen
Sorry. I am on my phone right now. So I missed some of your post. 🙁
How about total hardware99?
https://th99.bl4ckb0x.de/m/E-H/32707.htm
Reply 4 of 11, by brostenen
Back on track, with my computer now.... I have found something else, a site that I have not seen before.
Perhaps this is complete, perhaps not. As I do not have this motherboard, I have no real overview.
http://www.filewatcher.com/b/ftp/ftp.fic.com. … -vip-io2-0.html
Reply 5 of 11, by kanecvr
The files off http://www.filewatcher.com/b/ftp/ftp.fic.com. … -vip-io2-0.html are exactly what I posted above, just merged.
The ones off https://th99.bl4ckb0x.de/m/E-H/32707.htm are way more then what I had and better organised, but it's still missing the pull-down jumpers...
Reply 6 of 11, by brostenen
Well... Can't find anything else regarding this board. 🙁
Real shame. Perhaps someone here on the forum have a complete scan.
Reply 7 of 11, by brostenen
Looking at various sources. Are you shure it has pull/up-down? It might be kind of automatic, just like on pentium boards.
I simply can't find any sources that points to it.
Reply 8 of 11, by kanecvr
I'm not, but the VIP-IO(1) has them, and this board is very close to it layout-wise.
In any case, one of the links you posted is a really big help. Lots of settings not in the manual scans I have.
Reply 9 of 11, by brostenen
Thanks.... Thought that it might contain information that was left out or unread-able elsewere.
Regarding the Pullup/down thing.... Have been comparing the layout picture from the site I posted and total hardware, with the the info on jumpers that are there. And as far as I can see, looking at a glance, there are no Up/Down-specific jumpers.
The bad thing is, that I do not have the physical board, so I can not see if the pictures/drawings of the layout have missed 5 jumpers.
Not as many jumpers as on the 486 VIP IO board. The IO2 edition might have some Pentium era technology.
Sort of a late 486 board, from the time of were Pentiums were too new and too expensive and the 486's still ruled.
Perhaps in the time of mid-early to mid 1996? (april/june-96) Have not seen any releasedates or actual hardware, so it is 100% guessing.
Might even be from the same month's, just 1995 instead...
Reply 10 of 11, by PCBONEZ
With FIC you are usually better off going direct to their FTP site. It usually has more.
ftp://ftp.fic.com.tw/motherboard/manual/486/486-vip-io2/
Reply 11 of 11, by kanecvr
It's the same stuff I attached to the first post. Thanks for trying to help anyway! 😀
The link brostein put up has more in depth jumper settings so I'll try setting up using those, maybe it will fix the issue.
brostenen wrote:
The bad thing is, that I do not have the physical board, so I can not see if the pictures/drawings of the layout have missed 5 j […]
It's a late 486 board indeed, but the only real difference between it and the VIP-IO(1) is EDO support. If you use EDO, the board is pretty fast, but I want to use FPM on it, witch performs horribly.
It's a great board in some aspects (PS/2, PCI+VLB+ISA, voltage regulator that supports 3.3v, 3.45v, 3.7v, 4v and 5v and the IDE controller is pretty speedy) - but for it being a 1995 board it does not have flashable EEPROM and it does not have out-of-the-box 5x86 support. 5x86 CPUs are supported via bios update witch I have yet to do. It won't be running a 586 anyway - I'll stick my Intel DX4WB in it and set it to 120Mhz (stable in windows at 3.45v).
