First post, by sirlemonhead
- Member
Hi,
I've got this old Pentium 2 motherboard, made by some brand called PC Partner. It's missing the retention system for the CPU so I'm looking to get hold of one.
This looks the same as the one in my Gateway 2000 P2 machine - http://www.ebay.com/itm/Slot-1-CPU-Retention- … XMAAOSwv0tVFCVs
But then there's this type, which seems to have shorter posts? http://www.ebay.com/itm/Supporti-plastica-x-C … =item25a227155f
Which is the better type to get, or does it matter at all? I'm likely to be using a standard slot p2 cpu.
I also have one of these socket 370 to slot 1 adapter cards - http://www.cbo-do.de/shop/images/product_imag … ges/20823_0.JPG that I'd like to play around with but probably won't use...
Will this work with either type of bracket?
Thanks!
