First post, by superfury
When I use Dosbox video mode switch with VGA Monochrome graphics(mode 11h) with my reasonably correct VGA emulation on x86EMU without IBM VGA BIOS, I get blurry, messed up screen contents. Everything becomes very blocky(mouse reduced to some sort of rectangle). I simply change Windows 3.0 to it's VGA with Monochrome Display setting.
Dosbox 0.73 Windows 3.0 using VGA with Monochrome Display works without errors?
Anyone knows what's going wrong here? To reproduce, run Windows 3.0 without VGA ROM in my latest release. Then switch display setting to VGA with Monochrome Graphics. Is there an error in the VGA register values?
https://bitbucket.org/superfury/x86emu/src/aa … ode.c?at=master
UniPCemu Git repository
