First post, by psychz
- Member
Hello there! I recently built this PC:
- Soyo 025K2 with 486DX2 @ 66MHz
- 12MB RAM
- 6.4GB Seagate HDD (with WD EZ-DRIVE ODD, 4 partitions)
- Cirrus Logic CL-GD5426-based VLB SVGA (JDF 2theMax)
- Avance Logic ALS100 ISA sound card
- MS-DOS 6.22, Windows for Workgroups 3.11
Everything appears to work beautifully until I try to set up a memory manager. With EMM386 set up using memmaker's automatic settings, I had this issue where after exiting Windows, it would hang at the C:\> shell, with a blinking cursor, doing nothing, responding to no keypress whatsoever. I decided to undo everything, creating new autoexec.bat/config.sys files, and give QEMM97 a shot. It works fine, leaving me with 629kb available conventional memory, however I still get the crash when exiting Windows. Now that QEMM is in charge, it handles the crash like in the picture below. Tried playing around with QEMM's various options, mainly disabling almost every feature and re-"optimizing", to no avail.
Sometimes it's Exception 6, others it's 12 or 13, sometimes this message appears one more time after a keypress at this very screen. It's a bit less painful than before, since with this Quarterdeck QuickBoot feature it takes a bit less time to restart, but it's still annoying. Any experience on troubleshooting this kind of issues?
wrote:Its not like components found in trash after 20 years in rain dont still work flawlessly.
