First post, by CaelThunderwing
This one i cant seem to solve for awhile and im begining to think for some reason it's the Videocard 😒
(Trident 3DImage 9850) doesnt matter if i use the offical drivers or DisplayDoctor 7 the result's the same.
a friend's going to send me 2 spare ATI AGP Cards to replace this because this is Absurd (not to mention i know the 3DImage 9850 has alot of 3D Issues. ) but any idea if this card's on it's way out or possibly the AGP Slot is bad?
Reply 1 of 1, by Jolaes76
Bad RAM DAC, probably.
You can check for loose solder joints and overheating chips visually and manually. I think thorough inspection will require tools...
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
