First post, by nuninho
Hi, guys.
Welcome to vogons! 😁
Issue:
- we get crash to MS-DOS due to "division by zero" error when we press to hold by ~5 seconds "o" key to show "processor occupancy" and we get abnormally little faster than real-time.
Solution:
For Win XP (x86 - 32-bit only) (or newer OS 32-bit only as Win Vista/7/8.1/10) with "cmd" (command prompt) using, should decrease vertical frequency from your preference (eg: 70 Hz or faster) to 60 Hz. πŸ˜€
But for Dosbox emulator, we haven't any solution found yet, sorry. πŸ˜– ;(
NOTE: For MS-DOS native only we get NEVER "division by zero"! πŸ˜€ But we should show 640x480@60Hz. If you use CRT monitor 19" or bigger screen + videocard with PCI-e 2.0 used then we get 1280x1024 or 1600x1200 or other resolution screen at 85Hz - 85 Hz causes bit too fast. πŸ˜‰
--> Sorry for bad english. πŸ˜‰
Good luck! 😁
Best regards. πŸ˜‰
CPU: i7-12700KF
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 - NEW 😁
Opt. disc: LG BD-RE writer BH16NS40
HDD: SATA 1TB
SSDs: OCZ RD400 0.5TB+Crucial MX500 2TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 21" Sony E530 😁
Reply 1 of 1, by nuninho
Ah... I tested Intel Graphics HD 4600 (in my CPU i7-4790K) and I got 720x400@70Hz in text running MS-DOS native. And more any onboard graphics too or any videocard dedicated without PCI-e 2.0 support despite PCI-e 2.0 slot. πŸ˜€
--> Do you like this thread? πŸ˜€
CPU: i7-12700KF
HDD: SATA 1TB
