DOSBox in the taskbar.
First post, by mperelman
Until today, DOSbox would appear in the taskbar while I was working, both at home and at school allowing me to click on either the status window or the DOS box program that I was using. Now I can only click on the status window. Although, I can use a sequence of alt ab keys to navigate back to my work.
How can I correct this problem? And what would cause this problem today on two different computers. Any suggestions will be very much appreciated.
Thank you,
Michael
Michael Perelman
Economics Department
California State University
Chico, CA
95929
530 898 5321
fax 530 898 5901
http://michaelperelman.wordpress.com
Reply 1 of 4, by mperelman
I found a solution. Sorry for taking up your time
Michael Perelman
Chico, CA
95929
530 898 5321
fax 530 898 5901
Reply 3 of 4, by eL_PuSHeR
[Related topics merged and moved]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 4, by Kerr Avon
If you post a problem then find a solution, then you should really post the solution in case anyone else who has the same problem finds the thread when looking for a solution.
