Help with IBM Mystery Machine
First post, by asaggynoodle
Good day all!
I am posting here to get some help from this wonderful community that can hopefully help me to identify this ever increasingly strange IBM machine I've acquired recently.
So, from the outside the machine is Labled as a U.S. Logic DX4/100 machine, with a badge on the back that says "Made by IBM Corporation." So I'm going to draw the logical conclusion that the machine is sold as an OEM to U.S. Logic, whom from what i've scrounged up is a basically defunct IBM system seller, from 1995. I'm willing to doubt they have not made any computers in over a few decades, so no leads there. Upon closer inspection things take a turn for the strange when I'm greeted with an Empty 486 Socket... Meanwhile the machine still POST's with an "IBM DLC3 100Mhz" ??BLue Lightning?? CPU. Sure enough, right next to the IIT Co-processor is a Surface mount IBM 486DL3 w/ Fan and Heatsink. Nothing like having a dual 486 Motherboard? Strange enough, there is not a single Serial number, or Manufacturer mark (even from IBM) anywhere on the board.
The Varta 60MaH 3.0v CMOS battery had leaked, so I took the board out along with my newly discovered UMC UM85C4X8 SVGA card and pulled the battery along with the traces.. So after spending 20 minutes reflowing some jumpers and fixing the traces we're back in buisness... Upon search reveals a total of 5 archived results from a forum in 1995 about this same card, none of which provide any beneficial information.
Sure enough this board even has a pair of IDE Controllers on board...
I purchased an PS/2 to AT (5 Pin DIN) connector, to my amazement the keyboard still fails to work.. So I cannot get any device manager or serial numbers off the install (Which i'm 100% is still in there).
I have an Album of photos, here:
http://imgur.com/a/HDeQy
And some of the Case:
http://imgur.com/a/AQkxX
If anyone can please point out what kind of system I have here I would greatly appreciate that.. Or at least help me with figuring out how to get the Keyboard working unless I have to go out and find an inexpensive AT one.
Thank you 😀
--Sam
**EDIT, So i just went to the lengths of removing the motherboard and all of the ISA cards... I used my Reflow Station and pulled the DIN connector. Looks like the Battery Disolved all of the Copper plating around the Thru Hole rings, I tried my best to replate them and re-run the traces.. I believe I had done everything correctly and reflowed the DIN connector.. Put it all together and prayed.. Nope.. Same problem :L
So my question now, Is can I use one of those serial Keyboards or the ones that plug in via RJ11? I have a modem card with two jacks, and some other cards that appear to have serial connections..
Also, I've taken a picture of the motherboard itself for those who are still curious as to what it looks like. I cannot get a Money shot of the DLC3 because the Heatsink is actually Adhesived to the QFP of the CPU. So i'm going to not mess with it.. Since reflowing all those pads on accident would be a Bite in the sack.
Here is the money shot of the Motherboard:
http://i.imgur.com/Ak4ydlu.jpg
Reply 1 of 21, by asaggynoodle
I figured, you guys might know a bit about the peripherals.
So, I've got a HP PS/2 Keyboard (Literally just bought it for this purpose), That is plugged into the PS/2 => AT (5-Pin DIN).. I plug it into the machine and nothing..
No inputs register (I'm at the BIOS POST screen, and it's asking me to "Press <F1> to RESUME," but nothing is happening. So the machine is basically unusable as I don't have an AT keyboard to go with it..
I was wondering if it's something with the Keyboard, or the Connector itself? Should I just get an AT keyboard, or is there seeming to be a problem stemming deeper here?
Here is a picture of the adapter:
And here is the Keyboard I have purchased:
(HP Part number: 434820-002)
The BIOS screen also gives me "Keyboard Error," So I'm not sure where to go from here.
Reply 2 of 21, by 133MHz
Do you get the brief flashing of the num/caps/scroll lock LEDs when you turn on the computer? If not, the keyboard fuse on the motherboard could be blown, otherwise you might've missed a severed trace in your repair attempt.
http://133FSB.wordpress.com
Reply 3 of 21, by asaggynoodle
Thanks for the response!
Would this be the right fuse? Or is this for something else (since the AT connector is so close?).
http://i.imgur.com/r3MEa7u.jpg
**Edit, It appears to be not blow.. Plus for being 125V I'd be curious what someone tried to plug in there... Maybe Static... Well, I'll run a jumper and get back.
******* OH HEY!!! Yeah, It just made all the LED's jump High. Not sure if that is going to do anything for us, but yeah, they all came on for a second.
Reply 5 of 21, by 386_junkie
Hey!
Welcome to Vogons.
This is awesome... it's nice seeing another DLC3 out there and in a different 3rd party setup. I don't know how many 3rd party's got a hold of the DLC3 to incorporate into their systems but there were only a few, Alaris being another: -
A tale of 3 Blue Lightnings... tale 1
Once you are happy and have the system is restored... it would be interesting too see some Speedsys results, if you are able. The above link is from the results I got with the DLC3 on the Alaris board, this having the Opti chipset (known for reliability but not fantastic performance). Your board has a chipset i've never seen before... an EFAR? In any case, it would be interesting to see how well everything runs together.
Thanks for the thread.
Reply 6 of 21, by vladstamate
This works fine for me. I have a PS/2 keyboard that I connect to my 386 and 486. I even use a PS/2 switch and it is all fine. I am guessing something is wrong wither either the computer (very likely), adapter (unlikely) or the keyboard (unlikely).
The adapter I used initially, before starting to use the KVM switch, was not a cable base one but rather solid state with an AT male plug at one end and a PS/2 female plug at the other end.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 7 of 21, by dr_st
Something I never checked before: are PS/2 keyboards always compatible with AT, or is it like USB and PS/2 where the keyboard/mouse have to actively support both protocols?
Reply 8 of 21, by asaggynoodle
386_junkie wrote:
Hey! […]
Hey!
Welcome to Vogons.
Thanks for the Warm Welcome! I had just read your thread, I would LOVE to give some performance results once I get this thing going. It's really quite annoying that everything has survived this long, only to be basically barred by a simple keyboard connector. The strangest thing to me is that the only Chip that is Surface mount is the DLC3, I've NEVER seen anything like that before. It's very strange to say the least.. I thought the same thing when I seen that EFAR chipset too, I was like... Right...
I'm going to tear this thing down a THIRD time tonight (Hopefully), and just completely do without the DIN connector on the board. I'm going to instead run insulate jumpers to each of the Traces Directly, then Anchor them in the Thru Holes. Then I'm going to pull them through the Case where the original keyboard socket was, and mount them on the outside. So I can physically have access to each of the signals. Then, I'm going to see if I can reuse the old DIN connector and be 100% all of the signals are present. This way, If it still fails I KNOW for SURE that it's the keyboard.
There are about ~20 Jumpers on the board, both for the Empty 486, and ones referencing the DLC3. So with some of the equipment I have, I'll be able to not only Overclock the Shit out of that thing once we're rolling, but probably get to play with some Vcc stuff. So I'm really just excited to get to that point right now.
I'm fairly confident they do, but don't hold me to that. I've seen people do some crazy things like this:
Leads me to believe that all of the Signals (5v, CLK, GRND, DATA) are all pretty universal.
Reply 9 of 21, by 386_junkie
asaggynoodle wrote:
I'm fairly confident they do, but don't hold me to that. I've seen people do some crazy things like this: http://apt.bitcore.org […]
That is pretty funny.
Regards to your Keyboard prob...
You could try the keyboard in another system to rule in or out the keyboard itself?
If the Keyboard is ok... you could change the Keyboard controller? (the IC that is longer than the bios).
Another thing is possibly to check the bios for keyboard options & to enable/disable the a20 line.
All the best... I look forward to seeing some results soon.
Reply 10 of 21, by asaggynoodle
386_junkie wrote:
That is pretty funny. […]
Just like some of my other machines (This is the only AT/XT one I've currently got :L) they all have the keyboard options that tend to fix everything deep INSIDE the BIOS, so... I need a keyboard to get in there haha.
I'm probably pretty confident there is an option in there that will magically fix these problems. I wish I could just use an Add on card and run the keyboard through that (I'm not too familiar with anything pre-MMX/PCI), So if I could just use one of the Serial/Parrallel interfaces that would open a whole new door of options... instead of doing all of this reworking, but oh well!
I just tested the Keyboard - PS/2 AT adapter on three other machines, works perfectly. I should say, the The red fox jumped over the white fence just fine! So indefinably something with the motherboard.
Reply 11 of 21, by 386_junkie
If you have a DMM I would test continuity between the DIN connector on the motherboard and the keyboard controller (the IC longer than the bios) if there is continuity in all the lines there should be... then you may need to change the keyboard controller IC.
With there being a battery leak... my guess is that there could be a weak trace somewhere you've maybe overlooked, and if not... the IC got it in the face!
Reply 12 of 21, by asaggynoodle
That's a fantastic idea, I just found it.. It's Megatrends mega-kb-h-wp. I cannot find a datasheet on that, maybe someone else can help me figure out the pinout? I feel like I'm going to bend a lot of pins on such a large DIP if I try to pull it out. A DMM is literally the only thing I don't have on me at the moment, which is amazing as I usually always have my BK Precision, and Fluke 87v on me.
Reply 13 of 21, by Skyscraper
I often use a flat-head screwdriver to remove keyboard controller chips, just push it under the chip and lift, if possible first from one side then the other.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 14 of 21, by asaggynoodle
WOOOOOOOOOOOOOTTT!!!!!
IT IS COMPLETE!!!!!! I soldered jumpers to every pad, directly to the next/last IC in line to avoid the traces altogether. Then I pulled the Jumpers out from the case, So I can mount them directly.
It WORKS!!!! I am so damn happy right now, you guys have no idea.
http://imgur.com/a/bxgrs
Well, the last edited file was on December 7th 1997 (18 years, two months ago!!!!), So it's been a while since the last time anyone decided to use this puppy.
It apparently has Windows 95 installed, but fails to launch into a GUI due to Norton freaking out and causing me to abort the startup.
I'll be busy making a new CD-Diskette Floppy, and reinstall 95 on there.. Luckily, I'm able to see a UVGA folder which looks to have a few driver files on it. I will be copying those over and archiving the drive for further study. It also has Lotus, and a bunch of CAD386 software.. Pretty neat!
Reply 16 of 21, by asaggynoodle
gdjacobs wrote:
What's the insulation you used for that splice to the pins?
The same Wiring as the photo above, except I had cut off the Leads on the end to get the bare copper. Then wrapped it around each of the pins and soldered over it. I don't really have anything that's smaller Diameter. But it helps my Solder is 0.015" Which is pretty damn tiny (The smallest I could find).
Reply 17 of 21, by 386_junkie
Good... glad to hear you got it working.
Once you get the chance... could post on my thread your Speedsys results with your memory timings set to their stable fastest? I'm keen to see how the EFAR chipset differs from Opti. CPU, RAM and Cache are more or less the same.
Thanks
Reply 18 of 21, by asaggynoodle
386_junkie wrote:
Good... glad to hear you got it working. […]
Thanks
Will do!
The next hurdle is going to find a way to get windows 98/95 installed. For whatever reason all the boot disks i've tried cannot find the NEC CDR-1800A CD-ROM drive in the system.. So there is no way to get Windows installed. I guess I'll just take out the Hard Disk, format it in another machine, then extract the contents of my Windows 98se CD to the root directory of the drive.. Then boot back into the Boot Floppy, and execute the CD installation from the Hard drive.
Reply 19 of 21, by stuvize
Thanks
Will do!
Try using Compaq's IDE CD-ROM driver instead of OAK CD-ROM on your WIN98 bootdisk. Copy CPQIDECD.SYS to the WIN98 floppy and in the [CD] section of the CONFIG.SYS on the WIN98 floppy replace "DEVICE=OAKCDROM.SYS /D:OEMCD001" with "DEVICE=CPQIDE.SYS /D:OEMCD001"
The Compaq driver works with a lot of IDE controllers that OAK driver won't even works on Sound Blasters and most other ISA sound cards with controllers excluding OLP3-SAX. I decided to upload the driver since I'm not sure how easy it is to find the HP/Compaq website
    CPQIDECD.zip
    7.09 KiB
    15 downloads
    Compaq IDE CD-ROM driver for DOS
