Compaq Presario 433, my 486 pure DOS machine
First post, by jheronimus
Hi, all.
I've completed my second build, the 486dx2 Compaq Presario 433. And it's a beauty!
1.34 MiB
According to the label on the back of the monitor this machine was released in May 1994. It's largely similar to the first Compaq all-in-one, the Presario 425, and was succeeded by Presario CDS/CDTV series. Additionally, similar machines with an integrated NIC were available under the Prolinea brand (Net 1/25s, Net 1/33s, etc).
Hardware
The machine came in pretty empty: it had the original FDD and a 425,3 MB Western Digital Caviar 2420 HDD. The motherboard has 4 MB RAM soldered on and an integrated Cirrus Logic CL-GD5420 512K videochip.
1.77 MiB
All the electronic parts were working perfectly, but the mechanical parts did not age well. The power-on button works 50% of the time, and the plastic backplate of the motherboard cage broke off when I tried to eject the cage.
My plan was to get a 486DX2 CPU, upgrade the HDD to the Quantum Fireball 2.5a (2,5 GB), add some spare SIMMs I had from my Pentium build and use something from my heap of Vibra 16/AWE64 and ESS soundcards. It took me less than one day to get this machine to work the way I wanted, which is a huge step-up from 2-3 weeks I spent on my Socket 7 build. Having a lot of spare parts certainly helped. There were, however, some bad surprises.
First, the BIOS. Presario machines are said to have a proprietary GUI BIOS that must be installed to the hard drive. This is only partly true. Yes, if you really want a GUI, you need the recovery disks, those can be found here — they are universal for 425/433 and the CDS series. However, the system actually has a pseudo-GUI BIOS in ROM that has largely the same functionality. Anyways, I couldn't install the graphical BIOS to the disk, so I skipped this part.
1.72 MiB
Second, the HDD. My 2,5 gig Quantum Fireball was not detected by the BIOS or by the MS-DOS setup disk. I tried different HDD jumper settings, also tried telling the BIOS this is a 615 MB disk, but it just can't see it, and I don't know why. So I had to stick with the WD disk it came with. Scandisk says there are no bad blocks, but I realise that with a 22 years old HDD the system is bound to fail some time soon.
1.76 MiB
It says here that the disk controller is "WDC Compatible", could that possibly mean that it only accepts Wester Digital disks of a certain standard? I don't know. The guy used a "a laptop disk with an adapter", so I guess it should not have any restrictions. Could it be that the 2.5a disk was FAT32 (it has Windows 98SE installed) and DOS 6.22 doesn't support it?
Third, the RAM. The limit for this system is 20 MB. It didn't like my EDO sticks at all, so I had to stick with FPM modules. However, I could only use additional 8 MB (for a total of 12). Every time I tried adding another 8 MB resulted in the system entering an endless boot loop. Well, 12 MB should still be enough for a 486 machine, right? 😀
1.56 MiB
Fourth, the sound. This machine has two ISA slots and for some reason the ESS had to be installed into the first one. I only have ISA soundcards, so I can't tell whether it's due to a faulty ISA slot or not.
After all, here are my final specs:
14 inch 1024 x 768 CRT screen;
Intel 486dx2-66 CPU;
12 MB RAM;
425,3 MB HDD;
ESS AudioDrive ES1868F sound card;
Cirrus Logic CL-GD5420 512K.
P.S.: for some reason, the motherboard has a second power connector. It doesn't have a second IDE, so I don't know what it was supposed to be powering. Maybe I'll use it for a CPU cooler if my Socket 7 cooler fits on a 486dx2. Right now it uses a radiator.
Software
My first ever machine was my father's 486 Toshiba Satellite laptop running Windows 95 and my relatives' Windows 98 Pentium box, so I never actually used a pure DOS. However, seeing as how I don't have a lot of disk space, and this machine won't be used for any Windows games or software, using anything but MS-DOS seemed like a waste. As such, I installed MS-DOS 6.22 (with the additional tools from the 4th disk!) and Norton Commander 5.51.
I have to say, configuring MS-DOS seems A LOT simpler than a Windows 9x box. A lot of hardware does not require drivers or configuration at all. Even when some hardware does require additional software, it doesn't look for some unique version. I mean, all Compaq bundled software is compatible with all Presario 486 all-in-ones! Compare that to Creative soundcards each requiring different drivers and software under Win9x. So, after all, I did not have to do anything to get my videocard or my joystick to work. Configuring ESS was also a matter of installing some software (that is universal for all ESS cards) and modifying autoexec.bat).
I also got the CPQDOS bundle. The most important tool here is the MODE utility that is a software equivalent of a TURBO button. It can disable memcache and change CPU speed. The problem is that possible settings are: auto, common, high and fast. Which of those would be similar to 386? The docs don't explain that at all 😀
I also got some tips from here. The stock DOS prompt is atrocious if you ever used a Linux/OS X shell, so enhanced DOSKEY is a life-saver.
I used this article to configure my ESS AudioDrive. Have to say, even after setting everything to 15, it's still pretty quiet. I don't remember where I got the tools, so just google for "ESS_DOS_config.zip".
Games
Have to say, if setting up DOS was almost a walk in the park, getting the actual games to work is a nightmare — again, since I don't have any DOS gaming experience.
- Lands of Lore crashes after the character selection screen. I guess it's because the CPU is too fast, but I can't figure out the proper settings.
- DOOM 2 starts 25% of the time — it mostly just gives me a division by zero error. Even if I do manage to get to the main menu, the game waits a bit and then the screen quadruples and everything freezes.
- Wing Commander works pretty nicely with the Compaq mode utility.
- X-COM UFO Defense also runs well.
Any tips here?
Also I had a major disappointment with joystick support. Looks like most early 90s games like Wing Commander 1 and LHX don't utilise anything besides the stick and two buttons. So my Quickshot QS-201 is an overkill: its two extra buttons and throttle control don't work. Maybe my programmable Gravis Phoenix will work better though.
Next steps
I'm more or less happy with the specs now. It would be nice to replace the HDD, but it's not crucial. The biggest issue is data transfer. I'm just using my Socket 7 machine to flash IMG files on floppy drives, and it's annoying as hell.
I see the following options:
- LPT IDE CD-ROM. Pros: can play CD games, like Lucas Arts quests. Cons: messy (requires external power) and slow. Also, I can't find any offers in the Russian internet.
- ISA NIC. Pros: convenient. Cons: Hard to configure. Also, AFAIK, NICs use a lot of resources my DOS standards. Also not sure it would be too fast. Even my Pentium's 100 MB NIC is pretty slow.
- Insert a mobile rack into my Socket 7 machine. Right now it seems to be the cheapest and simplest option, thanks to Compaq design. Whenever I need to transfer a bunch of games or software, just take the disk out of Presario (it doesn't really need to be screwed to anything, and the cage is easy to eject) and write stuff directly to it. Use floppies for anything smaller than that (still amazed by how many DOS apps can fit onto a single 1,44 MB disk).
BTW, is there anything like a virtual drive for MS DOS? Is there a way to mount IMG/ISO files?
Conclusion
All in all, I'm pretty happy with this machine. I was lucky that all of its parts work perfectly well and it's pretty fun. Getting games to run will take some time to get used to, but this is why I wanted to do this in the first place, right?
MR BIOS catalog
Unicore catalog
Reply 1 of 88, by gdjacobs
That's a fine looking machine. I remember demos of Comanche running at the computer store on systems just like it back in the 90s.
There is a driver with the capability to mount ISO files in the SHSUCDX package, but it has no ability to work with CUE/BIN files.
Before pursuing an LPT CD-ROM further, I recommend checking for EPP compatibility on your board. ECP mode will be completely unsuitable for hosting an optical device. SCSI might be a better solution for your needs depending on what's available to you locally.
Reply 2 of 88, by MMaximus
Nice project and cool pics. Doom 2 and Lands of Lore should run on this computer, I think you might have some hardware problems. Maybe IRQ conflicts? I used to have them on my 486 back in the day... a lot of the games would crash until I figured out the sound card and the parallel port both shared IRQ7 or something like that. Otherwise maybe the memory might be faulty? You might want to troubleshoot.
Hard Disk Sounds
Reply 3 of 88, by jheronimus
Here is the error I get from Doom 2. Note that for that I disabled ESS by editing autoexec.bat (the ESSCFG and SET BLASTER lines). So I don't have any other devices and IRQs are only occupied by integrated parts at this point.
2.21 MiB
Lands of Lore doesn't produce any error, just a black screen and a freeze.
Is there a tool that would show me IRQ conflicts? Consequently, is there a tool to test the RAM?
Thanks!
MR BIOS catalog
Unicore catalog
Reply 5 of 88, by 386_junkie
Nice machine... I do like me an old Compaq. This is the first i've seen that incorporates a riser board. Thanks for posting.
Reply 6 of 88, by gdjacobs
I usually pull all cards and confirm the system operates properly in a base configuration. You can then map iRQ usage using a tool such as NSSI.
Give memtest86 a try! The latest release has a build for use on a floppy, and v4.20 has an EXE built for use under DOS.
Reply 7 of 88, by alexanrs
Just a little input: even if you do use any tools to mount ISO files this is not optimal. You lose CD-Audio that way, and that was used by a number of games for BGM.
Also, if you find the command prompt atrocious by default, you might wanna get 4DOS into that machine. It is a command prompt replacement that has low memory footprint, more advanced scripting commands, file name completion using Tab and a lot of other features.
Reply 8 of 88, by jheronimus
It's not really for large ISOs (the hard disk is 430 MB, 🤣). I was thinking about using that for mounting floppy .imgs instead of writing them as well as small (<100 MB) isos.
Like I said, I'm using Enhanced DOSKEY, but I've heard about 4DOS, too. Memory footprint isn't that much of an issue ever since I've optimized DOS memory consumption as described in this guide.
MR BIOS catalog
Unicore catalog
Reply 9 of 88, by jheronimus
LPT does look increasingly more attractive as there are some CD games I would rather play on a 486. There isn't a lot of documentation for this machine, though. Can I use software to detect whether or not it supports EPP?
Also, are there any caveats to using CD-ROM-s with LPT? I have a 12x IDE Pioneer CD-ROM, will it work with any LPT box?
MR BIOS catalog
Unicore catalog
Reply 10 of 88, by Tiger433
For Lands of Lore you need a patch or use a CD version of that game. I haved same problem years ago with that game on my laptop with PIII 600 and patch solved that.
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 11 of 88, by gdjacobs
NSSI tests for EPP mode. I'm not sure about external enclosures with LPT conversion. Most were all-in-one units.
Reply 12 of 88, by jheronimus
Thanks for the tip! Also, an LPT CD-ROM won't be able to pass CD audio, right?
MR BIOS catalog
Unicore catalog
Reply 13 of 88, by gdjacobs
They''ll have a CD out either on the back or via the front headphone jack. Pass that to your sound card via the line in jack.
Reply 15 of 88, by jheronimus
Holy shit, thank you guys for the NSSI tool! It's incredibly useful.
Yes, I don't have EPP, so LPT CD-ROM is out, unfortunately. But the NSSI includes CPU benchmarks, so I can actually check my slowing down tools. Cool!
MR BIOS catalog
Unicore catalog
Reply 16 of 88, by gdjacobs
Mind reminding me again what you've got for expansion slots? One remaining, right?
Does your motherboard have two IDE channels (four drives)?
Do you want to install a network card at some point, or is that unimportant?
I'm thinking you have two options at this point:
1) Use an IDE to SATA converter to allow an external eSATA optical drive connection. This also allows you to cold swap a size limited external hard drive (probably < 8.4 gb).
2) Install a SCSI host adapter to allow an external SCSI CD-ROM drive. This would be period correct and very compatible, but would preclude a network card.
Reply 17 of 88, by jheronimus
gdjacobs wrote:
Mind reminding me again what you've got for expansion slots? One remaining, right? Does your motherboard have two IDE channels ( […]
One free ISA slot. I don't think I'll be using a NIC. Only one IDE.
Will a SCSI drive support CD-R/CD-RW disks though?
MR BIOS catalog
Unicore catalog
Reply 18 of 88, by gdjacobs
Support for CD-R/CD-RW will depend on the optical drive. It will definitely support reading from CD-R and CD-RW media if it's a CD burner or DVD player. Those options are available.
Reply 19 of 88, by jheronimus
Damn those SCSI drives are expensive. I mean, since I have all the necessary components it would be about 10 times cheaper to get a Presario CDS — in case I REALLY need CD.
MR BIOS catalog
Unicore catalog
