First post, by DoomGuy II
I have an AMD K6-3+ build that I use for DOS games from around the 386 era to the Pentium era as well as games made specifically for Windows 95 before 98 came around. It works very well, but there are some problems with some older DOS games. Here are a couple to note:
CD-Man v1.5 [L1 and L2 disabled with 2x multiplier]: Twitchy intro screen (otherwise stable gameplay)
Dark Ages [L1 and L2 disabled with 2x multiplier]: Episode 1 returns a divide by zero error unless if I use the SLOWDOWN.COM utility. Episodes 2 and 3 return the same error no matter what.
Specs are as follows:
ASUS P5A Rev 1.04 Motherboard
AMD K6-3+ 450 (underclocked at 400mhz with 66mhz FSB)
128MB RAM
3DFX Voodoo 3 3500 TV 16MB Video Card
I've tried everything that I know, especially in the BIOS, to reduce the twitchiness and avoid the divide by zero error, but to no avail. Any suggestions?
Official Website: https://dg410.duckdns.org/
