First post, by Megadisk
I just received an Aztech Sound Galaxy BXII that is giving me a hell of a trouble. This has been tested into three different PC's (286 and 2X 386SX's) all with the same exact results. All tested under DOS settings (MS-DOS 5.0 & 6.22).
Basically, the main issues is when installing the drivers. The installation disks create the SGBXII directory with subdirectories and writes AUTOEXEC.BAT. The drivers installation begins ok, then it looks for the jumpers configuration and here's when the problem begins. It recognizes the Address and IRQ just fine but the joystick always displays as disabled no matter how many times I switch around the jumpers. Then near the end, it tries to test the card sounds (FM, SB, etc) and it always locks or crashes on this step. The issue almost seems to be related to the drivers themselves, but all of the ones I've found so far seems to be exactly the same ones (here at Vogosn, Driverguide, etc).
I installed new capacitors thinking that could solve the issue, but there was no improvement afterwards.
Any ideas? or does anyone has the original packing installation floppy images or can point me in the right direction please?
Any help is much appreciated.
The card looks to be exactly the same to the one in the vid video:
