First post, by BSA Starfire
308.28 KiB
Hi folks, I'm considering getting one of these VIA C3 1200mhz CPU's(same as above pic) but am unsure on the motherboard compatibility. Will this work in either a ASUS CUSL2 (intel 815e) or ASUS CUV4X(VIA apollo pro 133z). Or as these CPU's only for Tulatin motherboards? I have used a C3 866mhz in the CUV4X, it works fine but the BIOS does not recognize the CPU correctly.
I'm really struggling to find info on these VIA CPU's on the net, there isn't a lot and it's somewhat confusing. I know they are slow and quirky, but that is the charm for me.
Any help gratefully appreciated.
Reply 1 of 34, by matze79
i have also the same Problem.
i couldnt source a working Motherboard for it.
Even if they state it supports VIA C3, most of them support only the Erza/Samuel Cores..
Reply 2 of 34, by Tetrium
There was the VIA C3 verified motherboard list (a copy of it can be found on Vogonswiki here: http://www.vogonswiki.com/index.php/VIA_C3_Ve … otherboard_List ), but this list also didn't mention which exact chips would be supported. My best guess is that Nehemiah is likely to be compatible with Tualatin boards and only the pre-Nehemias would work on a board not supporting Tualatin (this is only a guess though as, as has been mentioned, it's hard finding a big cache of info about these chips and the boards that support them).
I do know I've once tried running a 1.2GHz Nehemiah in a Coppermine board (probably an ASUS board, though can't remember exactly which model number it had) and it did work the first time I had it post (voltage seemed to be correctly applied) but I ran into some kind of issues and decided to focus on other projects.
This however did imply the Nehemias didn't need a pinmod to get them working in boards that don't support Tualatin (as you may know, Intel switched a couple pins around when they went from Coppermine to Tualatin to prevent the newer chips from working in older boards).
My retro rigs (old topic)
Report spammers here!
Reply 3 of 34, by bhtooefr
Ezra-T was also Tualatin protocol, but I'm not sure how compatibility was for putting a Tualatin-protocol C3 on an old board. I'd guess that the list of boards with actual C3 BIOS support is rather short, though, and even shorter for Nehemiah - by the time Nehemiah came out, VIA was really being pushed into the Mini-ITX niche.
Reply 4 of 34, by Tetrium
It might be Ezra-T is to Nehemiah as Coppermine-T is to Tualatin, though frankly I don't really know as to why Intel even bothered creating Coppermine-T since afaik Tualatin boards would support ordinary Coppermines anyway. I never really bothered to figure this out as even back then info about C3 wasn't easy to find and also because I never owned any Ezra-Ts anyway 😜
Reply 5 of 34, by bhtooefr
In the case of Ezra-T, IIRC the split was on speed grades - the higher ones (933 and 1000) were only Ezra-T, and launched later. And, a reason to do it would be, the lower bus voltage would reduce power consumption, enabling the higher speed grades - VIA was desperate to get the slightest hint of performance out of ye olde Samuel 2/Ezra core, and pushing the clock was the only way to do it until Nehemiah was ready to replace it. (However, on Coppermines... I'm wondering if Coppermine-T existed so that Intel had silicon to test the Tualatin revision chipsets with, or something.)
However, looking at the Nehemiah datasheet, the CPU has two modes listed in the recommended DC operating conditions (page 4-12, PDF page 48) - Vtt for "legacy" Socket 370 boards of 1.365 to 1.635 V, and Vtt of 1.25 V ± 3% on "universal" Socket 370 boards. So, pre-Tualatin boards are explicitly supported.
Reply 6 of 34, by Ace
From my experience with the C3 Ezra and Ezra-T (933MHz and 1GHz models, respectively), there seems to be no difference between the two aside from the Ezra-T having more multipliers to choose from (they're multiplier-locked, but if you use Gerwin's SETMUL utility, you can change the multiplier on C3 processors on-the-fly). What I will say is both CPUs don't overclock very well. I don't remember how far I was able to push the Ezra, but I couldn't get the Ezra-T to run stable past 1.2GHz. At 1.25GHz, the CPU became very unstable and at 1.3GHz or higher, it would lock up.
I would be interested in testing a C3 Nehemiah myself, but I'm not sure if the two motherboards I have with C3 support will be able to accept the CPU. I've got the C3 Ezra running on a Soyo SY-6BA+ through a slotket (I can't run the Ezra-T on here without the FSB locking itself to 66MHz) and the C3 Ezra-T running on a Gigabyte GA-6VXE7+.
Creator of The Many Sounds of:, a collection of various DOS games played using different sound cards.
Reply 7 of 34, by matze79
Maybe its possible to inject the Microcode for the Nehemiah ?
I tried a few Boards and get a Picture but can't go to boot process..
And this boards are coppermine only..
has not philscomputerlab made a review C3 vs P3 ?
Maybe he can tell us which motherboard was used?
but i'm not sure about this??
Reply 8 of 34, by bhtooefr
Looks like microcode isn't the concern (the C5 family cores (Samuel (2)/Ezra(-T)/Nehemiah/Esther) don't appear to have a microcode update mechanism - that appears to have been introduced in the CN family cores (Isaiah)), it'll be CPU identification and speed setting that matters.
Reply 9 of 34, by gerwin
Below is from my own notes made in 2014. The Asus CUSL2 is mentioned. This in addition to my summary in the second post of the SetMul Topic. The MS6905 Master v2.3 Slotket is not Tualatin compatible, but I use it all the time with any VIA C3, Especially Nehemiah. On the other hand, I think that my non-tualatin VIA Apollo Pro 133A board required a Lin-Lin adapter in between the socket and the Ezra-T, not entirely sure...
VIA C3 Mainboard compatibility notes:
Mainboard       C5A  C5B  C5N  C5XL  Notes
My own tests (4x):
GA-6BXC OK OK OK OK (i440BX, MS6905 Master v2.3 Slotket (Except C5B on Tekram slotket), Award 6.00PG Powerleap Bios)
SOYO 6BA+III OK ? ? ? (i440BX, MS6905 Master v2.3 Slotket)
Shuttle HOT661 OK ? ? ? (i440BX, Forget to note slotket used)
Chaint.CT6AJA4 ? ? OK ? (IIRC with Lin-Lin adapter, This is a VIA Apollo Pro 133A board)
Internet info:
Abit BX133 ? ? ? OK (post screen spotted, Award 6.00PG)
MS-6309 VIA OK ? ? ? (post screen spotted, AMI BIOS)
Abit AB-BX6 NOT ? ? ? (Vogons user: gona, unknown slotket)
Asus P3B-F OK ? ? ? (Vogons user: gona, AA370TS slotket)
EPoX EP-693A OK ? ? ? (Vogons user: gona, socket 370 board)
Asus CUSL2 NOT OK ? OK (internet post. doesn't support Tualatin)
Above are private notes from me (gerwin), not official!
EDIT/UPDATE!: This Topic contains more compatibility testing that I did since.
VIA Cores for Socket 370(T) Desktop:
Code Name Core  Voltage    F.M.S   Process     Speed MHz  Intro Date  Longhaul
Joshua 2,20 6.5.0+ 0.18u 350..450 N/A N/A Actual Cyrix core, 256kB L2. CANCELLED after pre-release.
Samuel C5A 1,8-2,0 6.6.0+ 0.18u 466..733 11-22-1999 v1 Switched to Centaur 'Winchip 4' core, 2x64kB L1, no L2.
Samuel2 C5B 1,5-1.65 6.7.0+ 0.15u 600..800 07-12-2000 v1 64kB L2 cache added ('A' behind the MHz number).
Ezra C5C 1,35 6.7.8+ 0.15u/0.13u 733..933 09-19-2000 v1 process change.
Ezra-T C5M 1,35/1,45 6.8.0+ 0.15u/0.13u 800.1000 05-01-2001 v2 Tualatin socket rework, 'Nehemiah stopgap model'
Ezra-T C5N 1,35/1,45 6.8.8+ 0.15u/0.13u 800.1000 10-23-2001 v2 Switch to copper interconnect.
Nehemiah C5XL 1,4/1,45 6.9.0+ 0.13u 1000.1200 10-17-2002 v2 FPU now full speed, SSE instead of 3DNow, better MMX, cmov, 16-stage instead of 12.
Nehemiah+ C5P 1,4/1,45 6.9.8+ 0.13u 1000.1200 06-02-2003 v2 Added AES and second RNG (produced till 2006)
C7 Esther C5J 6.10.9+ 05-20-2005 ? probably not socket 370 compatible.
Reply 10 of 34, by BSA Starfire
Tested my C3 "ezra" 866MHz in the ASUS CUSL2 motherboard, it works just fine and recognizes the CPU correctly. So it looks as though it may well be OK with the nehemiah too. I have a EPIA motherboard on it's way with a nehemiah 1GHz CPU, it was actually cheaper than buying just the nehemiah socket 370 CPU by a pretty wide margin, so that will do fine for me at the moment to mess with nehemiah.
Best,
Chris
Reply 11 of 34, by bhtooefr
It's also worth noting that C5J definitely isn't Socket 370 compatible - it uses the VIA V4 bus, which is essentially the P4 bus modified enough to avoid infringing on Intel's patents. There were socketed C7s, but they were in a proprietary socket (IIRC mechanically identical to the Pentium M's µPGA479M, but not electrically identical).
Reply 12 of 34, by Ace
Decided to buy a C3 Nehemiah for testing. Now I just hope my two C3-compatible motherboards don't puke on this thing.
Reply 13 of 34, by BSA Starfire
Be interesting to see your results Ace. C3 866Mhz was slower than a mendocino Celeron 466MHz in my cusl2 with both final reality & Phil's ultimate VGA benchmark.
Reply 14 of 34, by BSA Starfire
eBay seller excepted a low ball offer for a C3 1.2 GHz Nehemiah socket 370 CPU. so should have benchmarks and impressions soon-ish. The EPIA 100000 has still not arrived after 8 days despite being local 🙁
Reply 15 of 34, by nforce4max
Did it even ship? Chances are that the seller either forgot or you got a scammed, be ready for the usual claim.
Reply 16 of 34, by BSA Starfire
Yes, the EPIA motherboard did ship, Hermes has had it since Wednesday 2nd. Been at my local couriers since Sat 5th apparently. Got a book coming from same couriers too on same time frame........eventually.........
Reply 17 of 34, by mattrock1988
I'm going to chime in here and let you guys know that I'm going to test out the VIA C3 Nehemiah 1.2 GHz chip in my Biostar M6VLR, which has a PLE133T VIA chipset, capable of powering Tualatin Pentium III CPUs. I'll report back if I am successful or not.
Retro PC: Intel Pentium III @ 1 GHz, Intel SE440BX-2, 32 GB IDE DOM, 384 MB SDRAM, DVD-ROM, 1.44 MB floppy, Nvidia GeForce 4 Ti 4600 AGP, Creative SoundBlaster AWE64 Gold, Aureal Vortex 2
I only rely on 86box these days. My Pentium 3 PC died. 🙁
Reply 18 of 34, by feipoa
I have a system built around the Nehemiah 1.2 GHz CPU. I run it at 1.4 GHz and stock voltage just fine. I am using an Asus TUSL2-C, which is based on the Intel 815EP chipset. I was really impressed with the web browsing performance of this combination, at least back in 2010. This has been considerable web bloat since then and the 512 MB limit of the Intel 815EP will likely be a problem.
Reply 19 of 34, by LSS10999
It seems some boards have issues with cache initialization for Nehemiah CPUs. I was able to boot a C3 Nehemiah 1.2AGHz on my ASUS CUV4X out of box, but the board recognized it as "Pentium II 1200MHz" with no cache memory (Cache Memory: None). Without the cache memory the processor is fine under DOS but extremely sluggish under Windows. I'm currently on the latest BIOS (1010.003).
Also, the BIOS additionally complained about unable to update microcode for CPUID=0000069A (which stands for Nehemiah) during the boot process. Given Nehemiah doesn't have a microcode update mechanism, it seems to be just a warning that it couldn't properly identify the processor. The board (CUV4X) is VIA C3 Verified, but so far only C3 Samuel support was mentioned in one of the early official BIOSes.
So it seems that pre-Tualatin boards may boot with the C3 Nehemiah, but in certain cases like mine, without internal cache, making it too slow to be practically used.
EDIT: Just tried a Tualatin adapter over the 1.2A Nehemiah on CUV4X. The result is the same as without it, the cache is still not initialized (None). Guess it seriously depends on whether the BIOS of a given C3-capable board can properly init its cache or not for a Nehemiah to work at proper speed, despite it can boot regardless.
