Super Socket 7 Problem
First post, by weldum
Hello, I want to make a k6-2 machine, I have everything but can't get it working.
I have various k6-2 processors from 333MHz to 450MHz and 5 Soyo SY-5EHM/5EH5 motherboards. One of these motherboards has the socket broken, so I used it as repacement to change some capacitors from other Soyo motherboards.
The problem is that none of these motherboards boot. I have a PCI POST card (I don't know what is the real name) but freezes at FF or 5F every time I power on these mobos.
I don't even know if is correctly configured jumper-wise. I've found a manual but seems to be for the 1.3 version, that has some differences. Mine are 1.0 and 1.1
The strange thing is that I had these mobo up and running. The last week I decided to dissasemble them in parts (jumpers, processors, ram, psu, etc). But now it doesn't work.
If someone knows what can I do (except buying something), because I don't know what to do.
PD: I have other socket 7 mobos but these are for 66MHz bus processors.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 6, by Skyscraper
weldum wrote:
Hello, I want to make a k6-2 machine, I have everything but can't get it working. I have various k6-2 processors from 333MHz to […]
Removing all jumpers from old motherboards is a very bad idea, often they have jumpers that isnt documented at all.
It's impossible for us to tell you whats is wrong without pictures, but if you have removed all jumpers I would start with double checking those.
Here is the manual for V1.1
The attachment Soyo SY-5EHM5EH5_v11.pdf is no longer available
Reply 2 of 6, by Imperious
Read the motherboard manual, do what it says, then report back
http://www.motherboards.org/files/manuals/107/m5ehv1310.pdf
Reply 3 of 6, by weldum
I've found the problem:
Soyo SY-5EHM/5EH5 v1.0/1.1:
Soyo SY-5EHM/5EH5 V1.3:
Was just a bad information problem. The manual I was using is for the v1.3, but there are small differences in between these models. The most evident is the fact that the processor multiplier switch has different adjustments from the same procesor for each mobo model. Luckily, the processors work very well. There was no damage at all.
Thanks.
Reply 4 of 6, by Skyscraper
Im glad we could help.
Reply 5 of 6, by Imperious
Apologies for the rubbish I wrote above, I obviously didn't read Your post properly. 😊
Reply 6 of 6, by weldum
don't worry, everything can be helpful
