First post, by Gorguss
- Newbie
Hi. Every time I launch DosBox with a Wireless Xbox One Controller active and connected, DosBox stops responding. Only fix is to set joysticks to "none" in the settings. Is there a way to make the Wireless XBOX One Controller to work with DosBox? Or am I the only one experiencing this issue?
/edit: Just tested with the XBOX One Controller connected with wire, same issue.
/edit2: Tested with old Wireless XBOX 360 Controller - Works flawlessly.
