First post, by shiva2004
Hello, let's see if someone on this wonderful forum can lend me a hand:
Some time ago I bought a Chaintech 6via5t. It's a pretty nice motherboard for a win98 build: micro atx, socket 370, supports tualatin micros, AGP and ISA... what is the problem? Well, it only works with the memory module included, a strange Kingston 256MB ECC module (I posted images of it here: Re: Post pictures of all your (strange) memory modules here for all to see :)). I tried many others modules of different size and speed to no avail, so if someday the module breaks a good, hard to find motherboard with a nearly unique combination of features will be out of comission.
All the modules I tried are regular, no ECC modules, so I searched both the net and the motherbard manual for information, but it seems than it should accept standard modules without trouble. There's no jumper or setting in the BIOS to force the use of ECC, and I even reflashed the BIOS, so I'm lost.
If somenone in this forum could help me to use no ecc modules with this board I'll be eternally grateful 🤣 .
