First post, by SuperHanSolo
I have been wanting to turn one of my DOS PCs to an old school MS-DOS gaming console.
I can connect it to a small TV with VGA and line out (PC speaker routed through the sound card for games without soundblaster support), then ill create a DOS batch selection menu to chose the game (i did it before, cant remember but i know it works).
In the selection menu ill have all the games listed, but the problem is ill only be able to select the options using a keyboard, it would be nice if i could somehow do it with a controller but that would require the gameport and controller driver to be run before the menu and even then im not sure if it would be possible to do anything with it outside of a game that has joystick support.
As a second option i could use a small wireless keyboard, but most are USB and im not aware of of an option available that will work on a old DOS PC.
Any suggestion or maybe a different approach
Win 98 Retro PC: AMD K6-2+ @ 550mhz, Mitac 5114VU motherboard, 256MB RAM, Radeon 7000 PCI 64MB DDR
Win 95 Retro PC: Intel Pentium 233mmx, Elpina M571 motherboard, 32MB EDO RAM, Voodoo 3 2000 16MB PCI
Main PC: AMD Ryzen 7700x, 32GB DDR5-6000, Geforce 3080
