First post, by Blades
Howdy, I have searched and yet haven't found a why or why not.
I have an Sound blaster AWE32 CT3780 and a SB32 CT3930 with 8 meg. (These are the cards i have and will use, as i wont' be buying anything else)
My question is, is that right now I am using the CT3780(awe32). Note :This machine im using is strictly DOS 7, no windows at all or ever for this rig.
It works fine for the most part, but the hanging note bug gets old and seems to happen too often(have to use the aweutil/s way to often to initialize and get rid of hanging notes when exiting games so much to the point of creating batch files with the aweutil/s in it when exiting)
Usually this happens when trying to play GM/Awe32 music for Lost vikings,X-wing floppy version,Hocus pocus/ROTT and other games and lately it seems to happen way to often.(Yes i run AWEUTIL EM:GM select GM when applicable on games(Hocus and Lost vikings), and select AWE32 when the option is presented(Rott and Doom etc...)
According to this website(good read)
http://nerdlypleasures.blogspot.com/2012/07/s … 64-options.html
it is because of the digitized sound and midi playing at the same time on the same card which can cause at times the hanging note and their recommendation is to use two different sound cards, one for GM and another for FM and other sounds.
-So my question, is there any merit to this?
-What kind of driver nightmare would i be running into, as it seems the SB32 CT3930 has different type of drivers than the CT3780. (of course i would keep the channels,irq and dma separate).
-Can this be done with these two cards? or....
-is there something else i could do to minimize the hanging note issue on the 3780(as it seems to happen more and more than when i first put together the machine)
-or should i run the 3930?
-Which would be the better of the two? the 3930 seems to be an Full AWE32 with ram slots but no bass/treble options in the drivers.
Again, I appreciate any answers you can give. The 3930 looks to be a decent card, and maybe my 3780 is taking a crap on me. I have used the correct drivers so i know its not that. This has been an issue that has slowly gotten worse over time(and only affects the MIDI/AWE32 stuff) the FM/Digitized stuff works great!.
Thanks again!
