First post, by 650Drew
So I'm having trouble with this card. I'm using it in DOS and I have the drivers loaded. The driver says IRQ is 7, DMA is 1, MPU401 address 330 MPU401 enabled with no IRQ channel. I have tried changing the settings for the MPU401, I've disabled it, I've enabled it with different IRQs, set it to share the IRQ, tried setting it to 300, tried my games on both 300 and 330 when the MPU401 was on different addresses and same address and nothing seemed to help. I'm not trying to use the MPU401 port, but I figured maybe it was routing the midi to it or something. I was just trying everything I could think of. If I set music to sound blaster or adlib it works fine but every game I try to use General Midi on it won't work. I attached pictures of the card and of the DOS driver settings. I also attached pictures of the MIDI settings and device resources under Windows 98. The card plays midi under Windows 98 perfectly which is quite confusing to me but it does say it using ESFM Synthesis (220) does that mean that it is using port 220 to do it's midi, shouldn't it be 300 or 330? I'm pretty good with Windows 9x but this DOS sound card stuff has me lost. The card has a wave table header which makes me wonder if it is trying to use that for the midi or something but since midi is working under Windows 98 I'm not sure what to think. Feel like I'm missing something here... Any advice would be GREATLY appreciated or I'll have to go back to my AWE64... NOOOO! (I jest, I love my AWE64, but I really like the sound of this card's midi and would love to use it!)
