First post, by anachronism1887
- Newbie
I have finally completed my Socket 7 build. I changed a few things and it is a bit more era correct. The main goal I had was to have something akin to my very first computer and to use as many new components as possible since I really like the idea of finding things sealed after 10+ years.
The biggest quirk I had was with the Soundblaster. It was listed as an SB4390 on the box, the picture of the back is of a CT4390 (erroneously assumed this was what I was buying) and the card inside is a CT4540 which matchs the label on the box. It works flawlessly in DOS (something I could not get the Audician 32 Plus to do). The onboard Yamaha OPL3X worked without issue in DOS so I regret buying the Audician but it will go into the Slot 1 system that I have coming along that will be strictly Windows based.
Specs:
*= New Item
*Intel TC430HX motherboard
*200MHz Pentium w/MMX overclocked to 233MHz (OEM)
*64MB (4x16MB) 60NS EDO SIMMs
*4MB ATI 3D Pro Turbo PC 2 TV (replaced 32MB ATI Rage Pro 128 TV Wonder)
*12MB STB Voodoo 2
*Creative Soundblaster AWE64 Gold CT4540
3COMM LAN
*Microsoft InPort ISA Mouse
320GB Seagate IDE hard drive (starting to look for low capacity disk)
*52X IDE Lite-On CD-ROM
LG IDE DVD/CD combo drive
*Teac 1.44MB 3.5" Floppy
*Mitsumi 1.2MB/360KB 5.25" Floppy
*400W Seasonic PSU (complete overkill but I won't buy cheap power supplies, it might get swapped with an Antec 300W that came with a case I just picked up)
IBM (Lexmark) Model M Keyboard
Swapped the buzzer for a real PC speaker since the case had a spot for it.
I don't know who makes the case since there is no branding or ID labels on it whatsoever. The person I purchased it from says he thought it was InWin but I couldn't find anything online that looked like it. But I really like the 3 panel (top and 2 side) design and there is a good amount of room for cable management. Unfortunately, he no longer had all of the bay covers so I have the redundant optical drives to fill space.
I am using a Dell P1130 (I hate the Dell aesthetic but I wanted a pretty close replacement for my NEC FE2111SB that stopped working). If I manage to fix/ find someone who can fix, the NEC I will go back to it as my primary CRT.
Any thoughts on what I could have done better or changed?
