First post, by JiaoTongNan
My laptop cannot use wireless internet and only works with Ethernet at the moment. I have the option to buy a wireless card (Which doesn't support WPA) or hope to find another Cardbus online that supports WPA2 and works with Windows 9x. Please name any cardbus or USB wifi adapters which work with Windows 9x and supports WPA2
I previously ordered a Linksys WPC54G Cardbus only to encounter issues which can't seem to be fixed. On Windows 9x, the required programs which come on the card's cd don't even work properly and slow down my laptop. I tried searching the cd for a driver, but nothing worked.
Personal Blog
Reply 1 of 17, by notsofossil
Just a heads up, WPA is almost impossible to get working on 9x. WPA2 is completely unsupported. WEP and unencrypted work fine with just about any 9x wireless card.
Thinkpad T42 Win9x Drivers | Latitude D600 Win9x Drivers
Next: Dell Inspiron 8000
Reply 2 of 17, by swaaye
I saw a suggestion to get another wireless router and run it in wireless client mode. Plug your old computer's ethernet into that. Much more pleasant than Win9x Wifi.
Reply 3 of 17, by JiaoTongNan
I believe its easier to do it for a PC than a laptop, we know for sure there are Wifi cards with WPA2 and Windows 98 support as well.
Here's a youtube video of proof, you just need the right wifi card or cardbus
https://www.youtube.com/watch?v=Xii5hP2yPck
Personal Blog
Reply 4 of 17, by mrau
less portable, but probably best performancewise - huge idea there
@op i once had an asus usb stick that came with a tool that did the whole wpa thing on pre xp platforms; i'll try to find that one if i can; just keep in mind that encryption does tend be slowndowner with old pcs;
ps https://www.asus.com/us/Networking/WL167g/specifications/ <-this one, but i see that they do not offer wpa for pre-xp, so i must have confused sth; i remember from the times when i worked on the dsl technical support, that the usb sticks the company sold did indeed have that option(always with the proper tool installed, no os support);
Reply 5 of 17, by Arctic
I used a USRobotics USR54 something Cardbus with a P120/32MB/Win98SE.
Let's say IRC worked well 😁
Reply 6 of 17, by JiaoTongNan
Please tell me specific model!~ This supports WPA2 right?
Personal Blog
Reply 7 of 17, by Artex
My setup works pretty well. I use a Netgear N300 Wireless Range extender (downstairs) in my workbench area that receives a wireless signal from my main router (upstairs). The extender plugs in any AC outlet and has one RJ45 port that I use to connect up to integrated NICs or ISA/PCI NICs on whatever system I'm testing.
Reply 8 of 17, by akula65
I don't know that this particular PC Card supports WPA2, but it does support WPA with AES for encryption. I have an old CompUSA SKU #333622 54 Mbps Wireless G PC Card that was manufactured by FMI that I have used with Win98 SE. Drivers and docs are available here:
https://web.archive.org/web/20060323041542/ht … .asp?SKU=333622
The drivers and docs postdate the release of WPA2 standard. FCC ID is NDD9573060509.
Good luck in your search.
Reply 9 of 17, by Arctic
Let me check...
It's a... U.S. Robotics 802.11g Wireless Turbo PC Card Model: USR5410 / 3.3v
Reply 10 of 17, by JiaoTongNan
Please name more if possible! I'm either having a hard time finding these online or WPA2 isn't available.
I found this cardbus, has anyone used this with Windows 98 before? I wanna make sure its not like my previous card bus that claims it has Windows 98SE supports only not to work!
SMC Networks SMCWCB-G
http://www.amazon.com/SMC-Networks-SMCWCB-G-W … s/dp/B0009YFZAW
Personal Blog
Reply 11 of 17, by Arctic
What if you use a USB 2.0 card along with a WLAN stick?
Reply 12 of 17, by RatCatcher
Netgear WPN511 works with WPA on Windows 98SE. Although it may slow down your wireless network if everything else is using N. If the laptop doesn't travel
It may be better to get a used wireless router and connect it as a client and use the Ethernet.
Reply 13 of 17, by JiaoTongNan
I need to make sure, does WPA = WPA2 ???
Will WPA-PSK work with WPA2-PSK?
Personal Blog
Reply 14 of 17, by keenmaster486
No. They're different standards; WPA2 is the newer one.
I don't know, but I'm 99% certain the answer is no, since they're different 😀
EDIT: BTW for wifi on 98 I just use a separate router, configured with an open network and a hidden SSID so I have a false sense of security 🤣
But seriously, where I live there's about 0.001% chance of a hacker exploiting my system, so it's OK for me.
World's foremost 486 enjoyer.
Reply 15 of 17, by RatCatcher
CardBus only supports WPA-PSK at the highest. WPA2 isn't supported good in win98. It is backwards compatible and will connect to a WPA2 router. It can and will slow down a mixed router if every other device is using N. You could get an old G router and patch it to your main router so N can do its thing. WPA-PSK is very hard or impossible to crack if you have a long password.
Reply 16 of 17, by HighTreason
Don't count on it. I live on a densely populated (or it was) council estate and nobody around me has WiFi. You'd think then that it would be the last place anybody would look for it. I had never enabled WiFi until a couple of years ago, I needed to do some testing for a laptop with a dead Ethernet adapter, so I decided to cheap out and just turn on my router's WiFi network... Within five minutes some dickhead actually parked his car on my drive, got out and started attempting to access the network with his cell phone, he even gave me a wave and a smile when I looked out of the window at him.
Now I use strong encryption, a very complex password and a MAC whitelist, among other things, to keep people out. The guy was lucky he drove off when I went for the front door or he would have been spending the remainder of the night trying to nick WiFi from Hull Royal's A & E department instead.
Reply 17 of 17, by gdjacobs
Why not expose him to some experimental malware payloads? "He connected to my malware research LAN."
