First post, by raygundan
I got Discworld 2 to run with VDMSound reasonably well. There is still some nasty audio skipping, even with the CDs copied to .iso images and mounted with VirtualCD (only works with low-level CD support, whether I use VirtualCD or the real CDs). That's all livable, though-- what's not livable is that when you exit the game, my windows desktop is horribly corrupted. Everything seems to work, you just can't *see* anything.
I'm using an Athlon XP 2000+ on a KT-400 motherboard, with a Radeon 9500 Pro and generic Realtek motherboard sound chips. I have a Lite-On 40X CD-RW. The only non-default setting I'm using in VDMSound is low-level CD support, which seemed to be required to get the game to find its CD.
Is there something I'm doing wrong that would cause video corruption on exit?
