First post, by philthethrill
I recently got an external floppy drive in the mail that I ordered from newegg. I'm trying to get the game The Lost Cases of Sherlock Holmes: The Case of the Serrated Scalpel to run in Dosbox. I mount the external floppy drive as A: and I also mount the C drive. I can't install it. I get a message saying the disk is not formatted properly.
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Are you mounting it as floppy? (-t floppy)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 3, by skitters
Can you see the contents of the floppy drive from Windows Explorer (not using DOSBox)?
Is the floppy showing up as A: in Windows or as some other driver letter?
Reply 3 of 3, by Dominus
DOSBox Moderator
right, I kind of forgot to move after replying to it 😀
@Phillthethrill: Dosbox questions belong in the dosbox forums, I moved this topic now
