First post, by QwErTyKb
Running Carmageddon with GliDOS is extremely slow, about 5fps. Any help would be great. Here is my info...
GliDOS version: 1.26
GliDOS settings for Carmageddon in Glidos.ini:
Executable: C:\intrplay\Carma\Carmav.EXE
DosGraphics: Yes
ControlJudderFix: 2
Resolution: 4
FullScreen: Yes
OpenGLid.ini settings:
Configuration File for OpenGLide
Info:
Priority goes from 0(HIGH) to 5(IDLE)
Texture Memory goes from 2 to 32
Frame Buffer Memory goes from 2 to 16
All other fields are boolean with 1(TRUE) and 0(FALSE)
Version=0.09rc6
[Options]
WrapperPriority=2
CreateWindow=0
InitFullScreen=0
EnableMipMaps=0
IgnorePaletteChange=0
Wrap565to5551=1
EnablePrecisionFix=1
EnableMultiTextureEXT=1
EnablePaletteEXT=1
EnableVertexArrayEXT=0
TextureMemorySize=16
FrameBufferMemorySize=8
OpenGLid.log contents:
OpenGLide Log File
***** OpenGLide 0.09rc6 *****
Date: 03/26/04
Time: 06:52:10
Clock Frequency: 637.94 Mhz
Configuration file is OpenGLid.INI
Wrapper Class Priority of 32
Wrapper Priority of 2
ColorBits = 16
DepthBits = 16
** OpenGL Information **
Vendor: NVIDIA Corporation
Renderer: GeForce4 MX 440/AGP/SSE
Version: 1.4.0
Extensions: GL_ARB_imaging GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_S3_s3tc GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shared_texture_palette GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_fence GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_register_combiners GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NVX_ycrcb GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_lod GL_WIN_swap_hint WGL_EXT_swap_control
OpenGL Extensions:
Extension GL_EXT_secondary_color is present and ENABLED
Extension GL_ARB_multitexture is present and ENABLED
Extension GL_EXT_fog_coord is present and ENABLED
Extension GL_EXT_texture_env_add is present and ENABLED
Extension GL_EXT_texture_env_combine is present and ENABLED
Extension GL_EXT_texture_lod_bias is present and ENABLED
Note: OpenGL GL_SGIS_generate_mipmap extension is supported but disabled by user
Extension GL_EXT_paletted_texture is present and ENABLED
Note: OpenGL GL_EXT_vertex_array extension is supported but disabled by user
Note: OpenGL GL_EXT_blend_func_separate extension is not supported, emulating behavior.
MultiTexture Textures Units = 2
Using Palette Extension.
Setting in Use:
Init Full Screen = false
Fog = true
Precision Fix = true
Wrap 565 to 5551 = true
Texture Memory Size = 16 Mb
Frame Buffer Memory Size = 8 Mb
MMX is present
** Glide Calls **
Operating System: Windows XP Pro SP1
Motherboard: AOpen AX34 Pro
CPU: Intel Celeron 633mHz
RAM: 256MB PC66 SD-RAM
HDDs: 1x 20GB Samsung ATA66 7200rpm, 1x 40GB Samsung 40GB ATA66 7200rpm
VGA: GeForce4 MX440 64MB
VGA Drivers: NVidia Detonator Drivers version 45.23
Sound: Onboard AC97
Monitor: NEC MultiSync XV17+
Resolution: 1024x768 @ 85hz
I thought it might be the sound that is causing choppy performance so I totally disabled sound and music in the Carmageddon sndsetup.exe program to no avail. I also tried disabling Forced Texture Smoothing and setting the resolution back to 640x480 and enabling Full Screen in GliDOS but it didn't help. Is my computer just too slow?
Thanks everyone 😀
