Question about r3980
First post, by NewRisingSun
I agree that fwrite should have sector_size as the third rather than the second parameter so as not to always return 1, but I don't understand why it makes a difference whether the last action was a read or write for deciding whether fseek is needed or not.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
from https://www.daemon-systems.org/man/fwrite.3.html
     Mixing fread() and fwrite() calls without setting the file position
explicitly using fsetpos(3) between read and write or write and read
operations will lead to unexpected results because of buffering the file
pointer not being set to the expected position after each operation
completes. This behavior is allowed by ANSI C for efficiency and it will
not be changed.
Water flows down the stream
