Dell "fridge" 2x P PRO
First post, by chose007
Hello, bought my new toy Dell PowerEdge 4100/180. That means original only one 180mhz cpu in it. Ofiicial support only 200/512.
I tried two 1MB pieces and posts good but in BIOS showing only 256kB. System is classic NT original by some company.
Including few SCSI Barracudas ... very noisy 😀 after turn off still running over 10s 😁
Everything is unstandart like usual by Dell.
Not planning big things with this, maybe better search two 200/512 cpus for original look than 1MB.
Some photos
Reply 1 of 21, by MMaximus
I don't know what that thing is but it looks scary!
Not sure about the thermal paste patterns on the CPUs though...
Hard Disk Sounds
Reply 3 of 21, by luckybob
There may be a bios update to allow the use of 1mb p-pro chips! Also, if you want a beast, get a pair of p-pro overdrives. ^.^
Reply 4 of 21, by Errius
Nice freight container.
That RAID card looks like an AMI MegaRAID Enterprise 1200 (Series 428). I have an Enterprise 1400 (Series 438) which is similar.
Is this too much voodoo?
Reply 5 of 21, by subhuman@xgtx
Beastly! Can you use CPU-Z/WCPUID to make sure the bios just isn't misreporting the processor's L2 size even though it might actually be fully functioning?
Reply 6 of 21, by chose007
Nothing bad about paste, only piece of poor art 😀
Ok will boot to system and will try CPUID.
Of course 2x 333 Overdrive is dream ... iam owning one but without original atypical cooler, hard to search two complete working pieces.
Dont know to much about these controlers, I have toon of them from other machines ... I know only one thing - not to easy setup this piece of HW 😁
Theres some other
Reply 7 of 21, by Jo22
How well does it run Windows for Workgroups ? 😁
Just kiddin', it's an awesome beast!
And it looks mighty! I can almost imagine to hear it growl..
Reply 8 of 21, by jheronimus
Holy shit this looks cool!
I particularly like the RAID controller. Seems like people back then were all like "everything is better with some RAM slots". 🤣
MR BIOS catalog
Unicore catalog
Reply 9 of 21, by luckybob
Actually the ram slots are required for proper i960 operation. In this case it's used as a cache for the scsi channels. These cards were awesome in the day. In theory, data passing between scsi channels never even touched the pci bus! I never tested this, but still. The i960 also used the ram to calculate raid 5 information. Even the newest sas/sata raid cards still have upgradable ram, and all have some sort of onboard ram.
Reply 10 of 21, by chinny22
Card above the i960 looks like an out of band card? (aka iLo/DRAC) with the PCIMI slot for a modem, Could be nice way to remote onto a NT server.
At first I was thinking while its very awesome, its too big and slow to do anything with, then it hit me, put a cloth over it and you have a table for next to the couch!
Struggling to think of what to actually use it for, but do love playing with this high level hardware!
Reply 11 of 21, by Errius
Power consumption is a concern with these behemoths. Play with them, but not too often.
Reply 12 of 21, by chose007
Yep its some kind of remote board.
These machines are pointless for regular use these days of course. Only collector item ... nothing special that I have problem with place 😀
Consumption for this Dell is good, I have another sharks which can send down circuit breaker in my room 😁
Well its weekend so will have time for this machnine and can make video with sound. I must replace 150kg schrott around to make place.
Reply 13 of 21, by Errius
Are you thinking of putting Windows NT on it?
Reply 14 of 21, by chose007
NT 4.0 allready in it
Actually back at work, I have no chance put some cpu-z or cpuid now to HDD because: only scsi, no usb, no lan here. Tomorrow put other stuff which will help.
I made video with camera but very poor so will make new with better one.
You can compare size with middle atx case under it 😀
Reply 16 of 21, by Errius
Cool. Listen to that roar. An old USB 1.1 card should work with it.
Reply 17 of 21, by chose007
Tried old USB PCI controller but not work. Finally found working scsi cdrom so result is that system use 1MB L2 at cpu so Iam happy about this.
But this NT 4.0 is only for one cpu so not working both actually.
I must put old versions of cpu IDs, new not working.
Reply 18 of 21, by chinny22
This is the original NT4 install right? Did it come with 2 CPU's originally?
I only ask as NT4 really doesn't like changing between single and multiple CPU's, just wondering if it's had that 2nd in there all this time not being used.
It can be done but its ugly
https://support.microsoft.com/en-gb/kb/156358
Reply 19 of 21, by chose007
Looks like original with 1x 180MHz cpu.
Thanks for tip with softmod. I will keep this original NT, only 4GB in mirror raid so not so good for anything.
Better put different HDD with new install.
