First post, by MrEWhite
When I use my MX300 sound card, the music in Wolfenstein 3D sounds lower pitched then will a real Soundblaster. Is this regular?
Reply 1 of 8, by PhilsComputerLab
It's possible, it doesn't have a real OPL3 and could be doing some sample rate conversion?
The strength of the Vortex 2 isn't FM, but the decent SB Pro 2 compatibility and wavetable header / MIDI port.
YouTube, Facebook, Website
Reply 2 of 8, by F2bnp
Yes, FM Emulation on the Vortex 2 is quite inaccurate. It does offer some unique sound in some games thanks to that inaccuracy, but I would avoid it if possible.
Reply 3 of 8, by MrEWhite
Anyway I could put a AWE64 Gold in with it without IRQ issues? I can't assign the usual ones to the AWE because the DOS emulation driver always takes it up and can't be changed
Reply 4 of 8, by PhilsComputerLab
Check out the "INF tweaks" from the Vogons driver archive. There is a version without SB emulation. It solves exactly your problem, that way you only have the Vortex 2 driver, no SB emulation and you can use your AWE64 without issues 😀
You unpack the driver, copy the INF tweak you want into the driver (over-writing it), then install it.
Reply 5 of 8, by badmojo
I have a Vortex 2 installed along side an ISA Audiodrive - the Vortex is for Win9x and the Audiodrive is for DOS mode. Deactivating the Vortex in DOS is easy - you just don't run the init software, and likewise the Audiodrive (non PnP) is invisible to Win9x. Works well.
Reply 6 of 8, by MrEWhite
I kinda wanted to use the Vortex 2 for MIDI with a daughterboard and the AWE64 for everything else under DOS.
Reply 7 of 8, by ynari
I thought the real advantage of the Vortex 2 was the A3D, I'm pondering getting an SQ2500 for my 'modern' gaming box so I can have the best surround sound in Half Life.
Reply 8 of 8, by MrEWhite
And that wavetable header 😜
