Zup wrote:Replace that fan ASAP!
That uCode loading error may mean that your BIOS has not uCode for that processor (=it is unsupported). Maybe a BIOS update can help, but before doing so I'd check if that CPU is supported at all.
The fan is brand new 🤣, with the fan on 100% speed this P4 runs on 34C when i'm with my AC on, the hottest that this processor reached on my tests was 40C so i guess that is not running hot.
The manual of the board said that it support Intel 65nm processors.
I will try to update the bios, if it didn't fix i will sacrifice the potato chips money to buy another Pentium 4 🤣
Edit: MEMTEST86+ passed with no errors, the CPU is being recognised on CPU-Z, and with Q-Fan control its running pretty quiet.
Edit2: After updating the BIOS the error is gone.
Edit3: I'm running Prime95 about 1hr for maximum heat and with the fan control setting it to 3000 rpm the P4 did not throttle down and the maximum temperature was 45C, Considering that intel ARK mention that the Tcase is B1+C1=69.2°C. D0=64.1°C i guess its running great.
