First post, by markot
I have a Octek Hippo VL+ motherboard but the manual is missing. Is there any place to get a copy of it? I had to remove the soldered battery from the motherboard because it had been leaking and would like to connect a new external battery to the motherboard.
http://s32.postimg.org/hvmr6fnut/octek_hippo.jpg
Reply 1 of 5, by dondiego
I've got the same board, you can download the manual from mobokive, well actually you'll need to use the wayback machine due to a bad configuration of the server. By the way mine comes with mrbios and i want to change to ami bios, is the ami colorbios the one that comes with the board?
http://www.elhvb.com/mobokive/archive/Octek/4 … 0VL+/index.html
LZDoom, ZDoom32, ZDoom LE
RUDE (Doom)
Romero's Heresy II (Heretic)
Reply 2 of 5, by markot
Thanks, this was good information. It was just surprising that the manual file was in WordPerfect format.
About the BIOS that is on the motherboard, I don't know what BIOS there is. I have not yet examined the motherboard that much.
Reply 3 of 5, by stamasd
Hehe, I used to have a Octek Hippo DCA2 back in the day. Complete with Mr.Bios also. 😀 It was a very decent 486 motherboard despite the outrageous claims about the DCA. I regret giving it away about 15 years ago.
(BTW the memory chips that you've got in there, are they the *correct* ones for the DCA? 😀)
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
