First post, by pentotark
Hello to everyone in the forum.
I recently bought a 3D Blaster Voodoo 2 12MB card to play Quake 2 with glide libraries.
Though, when I launch the game, everything is really bright to the point that some dark areas looks burnt.
Is that ever happened to you? Is there something I can do to fix this?
My pc is an AMD k7 700MHz, 128MB ram, S3 Trio 3D+voodoo2 card. It is runnig windows 98 SE with standard voodoo 2 drivers V3.02.02.
Thank you
Reply 1 of 11, by leileilol
If the 3dfx MiniGL's gamma of 1.7 bothers you, you can still use the full ICD the later 1999+ 3dfx drivers provide (Windows\System\3dfxvgl.dll) by setting gl_driver 3dfxvgl. This does not force a high gamma.
Reply 2 of 11, by pentotark
I'm a bit embarassed to ask this but, could you please help me doing that? Do I need to download something specific?
Thank you 😄''
Reply 3 of 11, by Gamecollector
Copy 3dfxvgl.dll to the Quake2 directory then rename 3dfxvgl.dll to opengl32.dll.
Select "default opengl" in the Quake 2 settings.
IIRC Quake2 minigl gamma controls work ok with Voodoo2 but you must restart the game. When you press apply - there are no changes.
Reply 4 of 11, by pentotark
Thank you very much!
Reply 5 of 11, by pentotark
I did what you said and works, but it does look exaclty as just setting opengl before from the menu. Is that okay?
Also I have another problem, every time i exit the game the pc goes back to desktop with artifacts, windows is still working and i can navigate the menus but the screen is messed up. Also, if I get back to windows while the game is still on the pc freezes. Maybe there is something I installed not properly?
Reply 6 of 11, by MrEWhite
Does plugging the card directly into the 2D card produce artifacts?
Reply 7 of 11, by pentotark
Do you mean plugging the monitor directly to the 2D card?
Reply 8 of 11, by MrEWhite
Yes
Reply 9 of 11, by pentotark
Trying your solution, I downloaded this file: http://www.falconfly.de/opengl.htm
renamed 3dfxogl.dll and put that into C:\windows\system folder
run the game
and wrote gl_drivers 3dfxogl inside the game console
but nothing has happened.
btw, reinstalling my S3 drivers, I don't have any artifacts issues anymore.
Reply 10 of 11, by pentotark
MrEWhite wrote:
Yes
It was, yes! So I reinstalled the S3 Savage4 drivers another time and that problem is gone now. =)
Reply 11 of 11, by MrEWhite
Ah, nice.
