1ghz tbird setup.
First post, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 1 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 2 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 3 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 5 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 6 of 38, by candle_86
Your board properly supports a Slot A 1ghz T-Bird right? If I remember AMD only shipped them to OEM's because off the shelf boards where not capable of running them period
Reply 7 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 8 of 38, by Jade Falcon
Rank BANNED
BANNED
I still have a lot of work. But it's getting there'.
Reply 9 of 38, by RogueTrip2012
I like that cable management, Good work.
Do you own the 1GHz already. I thought the 750MHz was faster due to cache speed.
Also make sure the caps are good on that mobo, I had a MSI K7 that had bad back in the day. I gave it away a long time ago sadly. The cpu was awesome at the time. The Irongate chipset wasn't so much.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>WXP/W8.1 . AMD 960T . 8GB . GTX285 . SB X-Fi . 128GB SSD
> Win XI . i7 12700k . 32GB . GTX1070TI . 512GB NVME
Reply 10 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 11 of 38, by sunaiac
My Tbird 1000 works reliably in my gigabyte 7IXE (bypass on or off), and in my gigabyte 7IX (bypass off only, older version of the chipset)
It is impossible to get it to work at standard speed in my K7 pros, I tested the three of them I have, bypass on or off.
It will work in those K7 pros, but only at 950MHz (9.5*100).
As for overclocking, I've tried 1100MHz quickly, without any pb. It should be able to reach 1150 on a 115 FSB which is the max reliable on this 7IXE. The next setting is 120 or more MHz, and no Irongate MB I tested can get more than 119MHz FSB stable.
K7 pros are better for overclocking than 7IXE, since you can go MHz by MHz.
Since K7 pro is the revised version of your MS6167, I think you're out of luck. If you find a way to make it work reliably, please share.
Oh, and you really want a super bypass capable MB too 😀
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 12 of 38, by Jade Falcon
Rank BANNED
BANNED
Super baypass?
Reply 13 of 38, by sunaiac
Jade Falcon wrote:
Super baypass?
It's a capability of the chipset that was disabled in first revisions.
If your chipset supports it, it will be present in the BIOS, under the name "bypass enabled" or something like it.
It gives a large boost in performance (Athlon 700 + bypass will basically be as fast as athlon 800 without)
I will post my bench results this evening to show you the difference.
Reply 14 of 38, by rein_ein
Keep it going,looks like gonna be some well worked at 98 or 2K build.
I also made one closely but much casually and using it as freaky daily XP machine with FX5900XT 😜
Reply 15 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 16 of 38, by sunaiac
Try 950mhz.
(10x95mhz)
Reply 17 of 38, by feipoa
Nice looking case. I love the look of beige coloured server-class cases. Might want to slow the fans down if they are too loud.
Reply 18 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 19 of 38, by Jade Falcon
Rank BANNED
BANNED
old post
