Reply 21 of 56, by keropi
^ there might be a way soon-ish to make a PAL 1084S-P1 ntsc compatible - changing the PAL decoder to the NTSC counterpart and adding/replacing some passive components. It's been under investigation from a more knowledgeable person, if it is a success I'll make a detailed post about the conversion. 😀
This would allow us to have a single monitor for TTL rgb, ntsc compatible composite/svhs inputs and a nice 15khz analog rgb monitor 😁
Reply 23 of 56, by VileR
@NY00123: to complement your PKCF post, I'll do a blog entry with some more details on the code... might help source/binary modders, I guess. Note that I didn't repack CKPATCH, only removed the existing UPX compression (I believe that UPX should have a 8088-friendly depacker option, but I haven't tested that yet).
@bjt: interesting -- that's a hXc setup indeed 😁 Is your CGA card a 'new-style' one, by the way? Might explain the extra saturation, although I guess that could just be the camera.
@keropi:
keropi wrote:
on a V20/10mhz the game is very playable
Nice to know! Was wondering about the minimum CPU requirements for acceptable performance (the 'typical' system that ran this game would've been a high-end 286/low-end 386SX, but those systems are unlikely to have CGA cards, let alone true IBM ones for correct colors).
Reply 24 of 56, by bjt
Yep, new style CGA. I have a V20 in my 5160 but it's too slow for this game really.
Reply 25 of 56, by SquallStrife
Fun fact, the game might run on an 8088, but the self-extractors crash (K4C1-ASP.EXE and K4C2-ASP.EXE). 🤣
Reply 26 of 56, by elianda
Does this composite version works as well with the video out from EGA cards?
(like this one http://www.retronn.de/imports/hwgal/hw_genoa_ega.html)
Youtube Channel
Reply 27 of 56, by SquallStrife
I capped* some gameplay footage, including toggling between RGBI and Composite.
https://www.youtube.com/watch?v=mVqXdndLIgw
* Shot my PVM monitor with my phone camera!
Reply 28 of 56, by bjt
No, unless you connect a board to the feature connector to create an NTSC composite signal.
Could be a nice project for someone.
Reply 29 of 56, by carlostex
VileRancour wrote:
@keropi:
I wish i could try it on my 12MHz V20 but i don't have a real IBM CGA card.
Anyway VileR this is awesome. Thank you sir!
Reply 30 of 56, by keropi
^ you really need to invest in one if you are serious about xt+cga stuff Carlos , there is no alternative sadly
SquallStrife 's video inspired me to make a quick video too, quality is not that great but you get to see how it performs with a 10mhz V20 😀
https://www.youtube.com/watch?v=ZAOIdin3I4U
Reply 32 of 56, by NY00123
Good to see you intend to write these details. Here is the PCKF topic for reference: http://www.pckf.com/viewtopic.php?t=3656
Regarding UPX, I've mistakenly assumed that you've used such an option of UPX. My copy of UPX appears to have an --8086 option, but since it's not exactly "8088", I don't know for sure if it'll be useful.
To the ones who wonder, I'll quick add that in addition to CKPatch, ModId (the Windows EXE currently available from https://github.com/owenmpierce/modId) was used for importing the graphics. While the patch takes advantage of CGA mode 6 (640x200x2colors), rather than mode 4 (320x200x4 colors) as usual, the graphics' layouts are more-or-less the same.
Reply 33 of 56, by SquallStrife
Quite the difference!
From what I understand, the EGA/VGA version should run a lot better, as the CGA version is quite CPU intensive.
Reply 34 of 56, by VileR
Heh, kind of surprising - the PVM preserves the 'stripy' appearance of the RGB picture even in composite mode, which probably means that its luma decoding bandwidth covers higher frequencies than usual. Guess I didn't consider such high-end equipment!
Curiously the game looks quite a bit faster than in Trixter's video... that *is* a stock 5150, though?
and potentially get 65,536 composite colors from EGA's 640x200x16 mode... hmm. 😁
Hey, that actually looks like optimal speed, or close enough anyway. Cool. 😀
Just standard terminology (the 8088 will run any 8086 code), so yeah, that's the option to use.
Reply 35 of 56, by Jo22
Awesome work! Congratulations on a job well done.
I've tested this patch on my "CGA" card and I'm glad to say it works. 😁
Scrolling is fine so far, just the colours are a bit funny, not to say funky.
But maybe that's either because of my setup or Billy hasn't seen a doctor in a while. 😀
Reply 36 of 56, by Scali
Yes, to elaborate on that: The 8088 is basically an '8086SX' in the same sense as the 80386SX.
It is the same CPU, on a smaller bus. So for applications there is no difference between an 8088 and 8086. The 8086 can just be a bit faster because it has a 16-bit bus, where the 8088 has an 8-bit bus.
So in programming parlance people generally refer to the '8086 instructionset', rather than 8088. But they are both the same.
Reply 37 of 56, by VileR
Yep, that's about what I expected a non-IBM card to do. I'm actually curious to know just what this card is -- could be an interesting data point for future experiments (hue is about 50° off), plus that text mode font could be a nice addition to my oldskool PC font pack thing...
Reply 38 of 56, by SquallStrife
Stock except for the Lo-tech 1MB RAM board!
Reply 39 of 56, by Jo22
Whew! I'm glad you're not angry about my pictures.
I've been a huge Keen4 fan and just had to test this awesome patch myself on the hardware I have!
The pictures were taken from a cheap LCD monitor, which claims to be multi standard (PAL/NTSC/SECAM).
I wished I still had my Commodore 1702 monitor, so I could have provided you with higher quality pictures.
Or any other old school monitor with a comb filter..
My setup:
386DX-40 with turbo brake enabled, caches disabled.
Epson Model Q205A ("CGA" card with mono/colour switch)
Philips 15PF4121
Here's a picture of my CGA wanna-be and a dump from that crystal memory.
I hope they're useful. I've tried to capture the resistors as best as I could.
    epson_cga.zip
    3.92 KiB
    130 downloads
    Epson Model Q205A control program/font
    1.26 MiB
    Epson Model Q205A graphics card
