computergeek92 wrote:Ok: […]
Ok:
AC Input (50-60Hz):
100 - 127v~/ 6a
200 - 240v~/ 3a
DC Output
+5v --/22a
+3.3v --/14a
+5vFP --/2a
+12v --/10a
-12v --/1a
+5v and +3.3v shall not exceed 135w
max output power 200w
My apologies for not getting back to you sooner.
The PSU looks very minimal, but as you said (and as I've heard from other retro PC builders), these PSUs should be good for their stated amps.
First of all, make sure your PSU pinout is compatible with the motherboard you intent to use. Some of these PSUs have some of the pins swapped around and without an adapter (these should be available on ebay for instance) you'll run the risk of frying something.
Next is the limited 200Ws of your PSU. The kinda good news is, is that I think it might be possible (no guarantees here. And it's your stuff so in the end you can do whatever you want with it). I know I've build s370 rigs using FSP 250W PSUs, but with those rigs I tried to keep the power requirements down by being more careful with which components I selected.
My Celeron 800 s370 rig (I just had a look) contains the Celeron 800 (obviously 🤣), a Voodoo 3, 3 sticks of SDRAM (64 megs each), single optical/hard/floppy drive and a simple sound card.
Personally, I'd try to get a more powerful PSU (300W with a nice 5v line) or downscale your build by losing one of the optical drives and perhaps also downscale the CPU to 800MHz and perhaps the graphics card too. I know you won't be happy to hear this, but if you had a 300W PSU, you wouldn't have this issue now.
A difference of 200MHz from, say, a 1GHz to a 800MHz Coppermine isn't very much, but the 1GHz may use up to 30W while the 800MHz often goes up to only 20W with relatively minimal performance loss.
I don't want to give you the green flag, it's up to you afaic.
