First post, by Elia1995
- Oldbie
... and I also know why !!! The problem is... I dunno how to fix it.
Hello, I'm running into this odd issue with the CT2950 Sound Blaster sound card in my Olivetti M4 434 S, it doesn't do that when I plug it into my oldschool / secondary PC speakers, but it does that when I plug it in my main PC's Line In to record the sounds when I have to record videos.
Since my Hauppauge HD PVR doesn't come with 3.5mm jack audio in, I have to record the audio separately with Audacity and then I combine audio and video in Sony Vegas, the problem is that the audio farts and a lot.
I said that I know what's the problem, so here it is: basically it's like the volume coming into my main PC's Line In is extremely high, causing the audio to muffle like that, the problem is that I don't know how I can fix it, there's no such thing as a mixer to lower the volume in DOS and the mixerset.exe program didn't solve the issue even if I lowered the master volume all the way down (obviously not at the point to mute it...).
I tried both with the Speakers Out jack in the sound card and the Line Out jack, same results on both, I've sticked with Line Out now.
Here's a video I just made on Raptor where you can hear that.
WARNING !!! Lower your YouTube volume...
Ah yes, a cool thing is that when I reboot the PC (the Olivetti, not my main PC), sometimes it farts a little less in some games. It's like some games "amplify" the volume and keep it like that even after I close them...
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
