First post, by matze79
Searching for a X1550 PCIe BIOS File with 128Mb DDR2 and 64Bit Memorybus.
I have OEM Dell BIOS on my Card and that means i can't use all Drivers.
Does anyone have one and can dump me the ROM ?
Thanks
Matthias
Thanks
Matthias
Have you tried generic drivers? I buy oem cards all the time and the only time I ever ran into any problems was with two 7900 GTX Duo that were pulled from an Alienware system. You should be able to find a bios on techpowerup....
OEM Radeons are certainly a bit harder to get going with generic drivers, but you should still be able to modify an .inf file to install normal drivers. I'd recommend wiping all traces of any OEM drivers first, as I've had issues where they would actually prevent other drivers from being installed.
This topic sort of covers what you're looking for:
http://forums.guru3d.com/showthread.php?t=378879
Given the age of the card, modded drivers from 2013 are probably as up to date as you're going to get.
http://digitalflem.mydiscussion.net/ May also help you setting up drivers on old radeon cards. I have been meaning to try that driver modder myself, but for some reason haven't tried it yet.
Ok, i did it.
i read out the BIOS and changed device and vendor id.
Now Catalyst 10.2 works fine.
