First post, by ratfink
A friend of mine has an Asus m3a79t deluxe board I gave him and recently bought 4x 4gb sticks to max out the memory. However the board will not post and says no memory. Reading the motherboard manual it seems that this board cannot use ram that has 128mb chips. Counting the chips there are 32 per stick, 16 each side in 2 rows. So they are simply incompatible.
Surprised me because I thought it was a pretty high end ddr2 board. It is certainly able to take 16gb ram according to the manual. It works fine with the current 4x 2gb.
Presumably there must be some motherboards able to use this memory, anyone know of any?
Reply 1 of 3, by Tetrium
If it's 32 chips in total, I remember motherboards having issues with such memory modules since forever basically.
I did try to use a couple 64MB FPM SIMMs which have 2 rows of chips per side instead of 1 and it tended to be unstable until I switched these modules for regular ones.
Could your modules possibly be server memory? (mostly registered modules).
My retro rigs (old topic)
Report spammers here!
Reply 2 of 3, by ratfink
It is labelled PC2 6400U, so should be unbuffered/non-registered.
Anyway the point is that the motherboard manual says the ram won't work due to the chip size [128mb], I really just interested in knowing if there are any DDR2 motherboards that will take it. Is it a chipset limitation for example. The memory controller is built into the CPU [in this case, a Phenom II] so that's not the issue as it's the board that claims not to be compatible.
However googling suggests this is high density ram which is often cheap, but usually incompatible and often slow, so this may be a dead horse there's no point flogging further. I suspect this likely involved an unscrupulous and misleading ebay seller.
Reply 3 of 3, by NJRoadfan
Unbuffered/unregistered 4GB DDR2 modules aren't officially supported by any consumer class motherboard that I know of. Some X38/X48 boards have BIOS support for the FB 4GB modules, but those were targeted at workstations. The industry jumped to DDR3 before they would have been commonplace.
