First post, by theelf
theelf
Offline
- Oldbie
Hi,
I have a problem in one game, Sango Fighter 2 (super fighter team version). When the intro start, dosbox change the video to 800x600 or first high resolution that find, instead of the original 640x480
Because wrong resolution, i get 640x480 image centered in high resolution. I already tried vgaonly, svga, etc no luck
This is with fullresolution=original and surface
In real DOS PC, the game use 640x480 for intro and screens
The only way to "solve" the problem, is for example to crate a resolution of 640x482 , and then dosbox select this resolution instead of 640x480, and because is almost same, no difference at all
maybe is a dosbox bug?
Thanks
