First post, by computergeek92
I wonder what the typical mhz change is for certain stock cpu speeds for the equivalent cpu they underclock. I'm curious about if the 486SX 25 becomes some 386 speed, or does a 486dx2 66 become a 33mhz 486?
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
Reply 1 of 4, by elianda
The problem here is that the Turbo Button functionality is not directly related to changing MHz. Depending on implementation it adds Waitstates, disabled chipset buffers, disables caches and so on.
Youtube Channel
Reply 2 of 4, by computergeek92
Really? I saw cases that had the front "mhz" led go from 33 to 16 with the touch of the turbo button. I thought It meant equivalent cpu speed to another slower cpu.
Reply 3 of 4, by PhilsComputerLab
Yea that's not how it works. The LCD display if cosmetics only. It has two states and you can configure what it displays with jumpers at the back.
Some change it display HI and LO for example.
YouTube, Facebook, Website
Reply 4 of 4, by chinny22
Yeh most are controlled by jumpers on the back of a display
I re used a 66Mhz case for a 200Mhz Pentium, but never to change the display. Also pressing the turbo button still changed the display even though it wasn't connected to the motherboard at all.
Also there was no standard on how turbo should slow down a system. Different companies had different ideas on how to do this.
So 1 motherboard may slow a 33 down to 16, another may slow it down to 12Mhz
