First post, by GL1zdA
So, I want to finally put together my fast Windows 98 SE. I have chosen the hardware to match 98 SE limitations:
* Asrock 775i65G - since the 865 has Intel's support under 98.
* Intel Celeron 1.6 - to not hit the 2.1 GHz barrier
* 512 MB RAM - to not hit the 512 MB RAM barrier
* an nVidia AGP card (currently Quadro 3000G) - for official 98 drivers
I really don't want to use all the fan-made patches, I'm trying just keep compatibility to the maximum.
Now I wanted to reuse an old 160 GB S-ATA drive and problems appeared. I have set the motherboard to compatibility mode (2 S-ATA channels + Secondary IDE). I don't need to use the whole capacity, I'm happy to use the first 128 GB (even first 40 would be OK), but the drive doesn't have the "limit to 137 GB" jumper. FDISK goes nuts, so I'm using Ranish Partition Manager, but that's OK - I won't need FDISK after installing 98 on this machine. Whatever partition I create (tried 120 GB, 8 GB, 2 GB), even though FORMAT works, SCANDISK fails with "Scandisk cannot read from last cluster on drive C". What should I try now?
getquake.gif | InfoWorld/PC Magazine Indices
Reply 1 of 6, by FaSMaN
Sorry posted without reading your whole post its not a bios limitation your experiencing.
You can use 3rd party replacements for Scandisk, Norton utilities comes to mind (Norton DiskDoctor), or Partion Magic also had a package that replaces windows scandisk, defrag also wont support 137gb disks.
Edit: there is a lovely thread over at msfn that includes replacement scandisk and defrag executables that fix the problem Norton DiskDoctor
http://www.msfn.org/board/topic/129027-big-hd … a-thread-index/
Replacement executables: http://www.msfn.org/board/index.php?showtopic=103334
Reply 2 of 6, by PhilsComputerLab
Scandisk being a 16 bit application, I think it doesn't go past 64 GB? But not 100% sure.
YouTube, Facebook, Website
Reply 3 of 6, by GL1zdA
Only FDISK is affected by the 64 GB bug: Fdisk Does Not Recognize Full Size of Hard Disks Larger than 64 GB. Other tools and 98 SE should support everything up to the 137 GB (128 GiB) barrier (LBA28 limit). That's why I've created the partition at the beginning of the drive and to be less than 137 GB.
Reply 4 of 6, by PhilsComputerLab
This KB article confirms what you say:
The ScanDisk tool included with Microsoft Windows 95 and Microsoft Windows 98 is a 16-bit program. Such programs have a single memory block maximum allocation size of 16 MB less 64 KB. Therefore, The Windows 95 or Windows 98 ScanDisk tool cannot process volumes using the FAT32 file system that have a FAT larger than 16 MB less 64 KB in size. A FAT entry on a volume using the FAT32 file system uses 4 bytes, so ScanDisk cannot process the FAT on a volume using the FAT32 file system that defines more than 4,177,920 clusters (including the two reserved clusters). Including the FATs themselves, this works out, at the maximum of 32 KB per cluster, to a volume size of 127.53 gigabytes (GB).
If your drive is Seagate or Samsung you can try Seatools to limit the capacity.
Or use FreeDOS FDISK or Super FDISK to create a 120 GB partition. Maybe 128 is too close to the limit?
Reply 5 of 6, by GL1zdA
The problem is, I've tried also an 8 GB partition and 2 GB partition and the error is always the odd "Scandisk cannot read from last cluster on drive C" (it doesn't even start to scan the drive, it just launches and displays this error). The drive is a WD drive, WD1600JS to be exact.
It seems I can limit the drive capacity by using ATA commands. Will have to give Host protected area: Manipulation methods a try.
Reply 6 of 6, by NJRoadfan
just don't use scandisk, period. "setup /is" when you install Windows 98 avoids the problem.
