First post, by Oldskoolmaniac
Ok so im trying to build this computer around the year 95 - 97 so far i got 95 up and running the only driver i cant find is the Diamond Stealth 3D 2000 S3-ViRGE VX PCI driver.
Im also hopping to get dos mode going and play wolfenstein 3d as well as others, ill have to import it from my gog download tho.
Specs are:
Video: Diamond Stealth 3D 2000 (I hear it lacks 3d)
3dfx Voodoo 1 (lacks 2d)
RAM: 32MB EDO
HDD: 2GB Western Digital (Bigfoots dead wont spin up at all)
Audio: Creative AWE64
CPU: Pentium-MMX 233MHz
Motherboard: MS5129 (clock battery is dead, no idea where it is located or where to get a new one, also board claims to have usb header but i have no idea where)
    1.63 MiB
    MS5129 v.1.2 Motherboard
    1.82 MiB
    Creative AWE64
    2.21 MiB
    Case Side View
    1.42 MiB
    Case Back View
    1.49 MiB
    3dfx Voodoo 1
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 42, by Oldskoolmaniac
Im pretty sure this is a virge vx series
Reply 2 of 42, by FFXIhealer
Without turning over the board in my own hands, I can't be sure, but looking at your picture, this is what I think...
    1.96 MiB
    Added Points
Reply 3 of 42, by Oldskoolmaniac
thats was i was thinking for the usb but did these boards not come with batteries?
Reply 4 of 42, by keenmaster486
The CMOS battery is inside of that Odin real time clock chip. You'll have to either replace it or cut into it and solder a new battery on.
World's foremost 486 enjoyer.
Reply 5 of 42, by Oldskoolmaniac
would i be able to solder a socket for a stander watch battery at the top, or would i have to do the dallas mod?
Reply 6 of 42, by psychz
Do the dallas mod, which will allow you to solder a CR2032 socket on top of it!
Stojke wrote:
Reply 7 of 42, by FFXIhealer
I'll tell ya, though, looking at that motherboard brings me back to my pre-teen years and my father's old 80486 MS-DOS PC. It had Windows 3.1 on it, but you had to type in the command to start it and we used to play mad DOS games on it like Wolfenstein 3D and DOOM, Jet Fighter Advanced Tactical Fighter, Star Wars X-Wing, and the like.
Reply 8 of 42, by Oldskoolmaniac
ok so here what i found out http://www.hardwaresecrets.com/replacing-the- … oard-battery/3/ and here's what i ordered http://www.ebay.com/itm/5Pcs-DIY-CR2032-3V-Bu … AsAAOSwUV9Woy9F
Reply 9 of 42, by candle_86
4x2 block of pins next to other I/O ports likely a USB 1.0 header
Reply 10 of 42, by Oldskoolmaniac
i looked at is closer and it says usb next to it.
Where might one find connector for that to a pci slot, only ones i keep finding on ebay are the usb 2.0 ones
Reply 11 of 42, by FFXIhealer
http://www.ebay.com/itm/like/141718217822?lpi … s&ul_noapp=true
Something like this will do. This is just an example I found quickly on the Bay, but maybe you can find one in your area.
Reply 12 of 42, by Oldskoolmaniac
would that still work with usb 1.0
Reply 13 of 42, by FFXIhealer
The difference between 1.0, 1.1, and 2.0 is all bus-based. The wiring are identical. It's not until you hit USB 3.0 that extra wires/contacts get added. That device would work with any USB port up to 2.0.
Reply 14 of 42, by nforce4max
Pretty system you are building there, I would pick a better sound card that has native opl3 in some form. Beyond that you are on the right track to building a good dos and early 9x system. As for the S3 yes it doesn't have much bang in 3D and people called them back in the day 3D "de-accelerator".
Reply 15 of 42, by jheronimus
Maybe try the driver for the 2000 Pro? You can find it here as well as some other S3 drivers.
MR BIOS catalog
Unicore catalog
Reply 16 of 42, by Oldskoolmaniac
yea ill give that a try, im waiting for my pci ps/2 port card to come, its a pain navigating through windows with a keyboard.
Reply 18 of 42, by Oldskoolmaniac
not yet im going to solder in a coin battery, there is a slot for it on the board. I will post back here in a few days when I get the battery holder in the mail.
Im going to be redoing this project with the same board, I will have a brand new AT case for it as well.
Reply 19 of 42, by Errius
I was wondering about that. The +ve trace leads directly to pin 20 on the RTC chip, same as the "dallas mod" people have mentioned. However the -ve trace doesn't lead to pin 16 as the mod requires. (it doesn't seem to lead anywhere) Will it still work?
Also there are no holes for the battery holder pins. How to solder it in place?
Is this too much voodoo?
