First post, by matze79
Hi,
does anyone here own a 586TX3 and could help me out with the Pin Assigment of the PS/2 Header ?
i already build a cable but it doesnt work,
a polish website gave me this Information:
1 - + 5 V
2 - GND (masa)
3 - mouse clock
4 - mouse data
2 seems right and is GND, i already measured this.
I connected my PS/2 Port according to this Pinout.
Mouse is powered up, but isnt recognized at all.
BIOS includes PS/2 Support.
Its only activated if mouse is detected on Bootup, as far as i know.
Because 3-4 are without voltage in msdos mode.
Thanks
Matthias
EDIT:
Attached BIOS File for K6-3, fixed ATA133 Harddisk and K6 Write Allocation enabled etc.
Reply 1 of 5, by obaltus
Hello,
I am facing the same issue. I wan to build a PS/2 mouse header for a GIGABYTE 586T2 which is very close to yours but I cannot find the pin-out assignment. Did you manage to have cable working?
Would you mind sharing your findings?
Thank you
Reply 2 of 5, by adalbert
You can always just try finding ground and +5V lines, using a multimeter or by visual inspection, then just try switching around clock and data pins.
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
Reply 3 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You can also find out which pins are data lines (not which one is which):
- multimeter in diode test mode
- red probe on GND
- check the remaining three pins with the black probe. Data lines will show a stable value of around 400-800(mV).
1+1=10
Reply 4 of 5, by Eimer
matze79 wrote on 2016-06-25, 13:48:
Hi, […]
Hi,
1 - + 5 V
2 - GND (masa)
3 - mouse clock
4 - mouse data
Thanks
Matthias
EDIT:
what was it now?
I'm facing the same issue. Same board.
Reply 5 of 5, by Disruptor
Yes, those legacy PS/2 (and DIN) connectors are not plug and play.
Basically you have to connect legacy PS/2 mouse and PS/2 or DIN keyboard before powering up.
(However, a serial RS232 mouse does not have that issue.)
