First post, by ibm5155
I have a netbook with that cpu, and all the time the mic is enabled and I Always hear the mic sounds over the speaker when using Windows, but not when I'm running dos, so, is there some tool for disabling the mic or at least making it not audible over the speaker?
Reply 1 of 2, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
"Windows"
Check your mixer options (not only the default view).
1+1=10
Reply 2 of 2, by ibm5155
The thing is, the recorded volume doesn't show nothing over the "volume control" bar...
And I also can disable any tool over the recording control and I still can hear the mic.
Also, I cannot mute the mic over the recording control.
EDIT: Uh, I found it, it was a hidden option over the output....
